Results 1 to 20 of 20
Thread: hoping for a solution
06-17-2008, 07:31 AM #1
The fender tab under the car behind the front wheel snapped where it bolts down. The tab itself is fine, but the whole thing is just broken at the crease. The fender thing just kinda flaps around with nothing holding it in place. Is there anyway I can fix this?
Its hard to see but it sticks out a little
06-17-2008, 08:06 AM #2
Hmmm...possibly 3M "Trim and Emblem Adhesive"......I've used it on several occasions for plastic repairs on cars and it's very strong and durable....if anyone else has any suggestions or thinks this will/will not hold up, feel free to chime in.....just my opinion...
06-17-2008, 08:16 AM #3Pony Killer
- Apr 2008
- Mississauga, Ontario, Canada
Black- 2002 Camaro SS M6
some sort of 3m tape sounds like a good idea. if not, there are many different types of welding putty available for different applications. there should be one that is meant for plastic.
06-17-2008, 08:25 AM #4
it's hard for me to picture how it's broken but most likely you'll need a new quarter panel.
06-17-2008, 08:28 AM #5
06-17-2008, 08:30 AM #6
06-17-2008, 03:05 PM #7
06-17-2008, 04:07 PM #8
06-24-2008, 06:26 AM #9
I snapped a quick pick the other day and forgot to put it up here
06-25-2008, 07:24 AM #10Pony Killer
- Apr 2008
ouch... i dont think putty or tape would hold that together, i mean you could try, it would only cost couple dollars to try both options, but i think you'll need a new fender.
Other option is get creative and start drilling some holes and make some brackets to hold it, but a new fender would be best. (i have jumped into orion's boat, i completely agree with him now).
06-25-2008, 08:09 AM #11
balls...that sucks. I mean it doesn't look too bad from the outside, it just sticks out like 1/2 an inch more than it should, but it's totally screwed from underneath i guess. I guess one of the past owners or a shop or something tried jacking it from there and I didn't notice when I bought the car. I guess I'll just leave it the way it is for now,
thanks for the advice guys!
06-26-2008, 02:26 PM #12Senior Member
- Feb 2006
- Orange County, NY
You can try some fast setting epoxy. It is worth a try.
06-26-2008, 03:20 PM #13Member
- Tulsa,OK
Quick Silver- 2002 Z06
I would try the epoxy route. Unscrew it put something behind it so it bows out and tape the broken piece to it and use epoxy.. Probably will hold..
That is probably better then just leaving it to flop.
Otherwise, like said above... New fender time.
Camaro Owners Click Here
Firebird Owners Click Here
www.AutoTrix.net
06-26-2008, 05:22 PM #14
alright, sounds like a plan. I'll prob try and fix it this weekend.
Thanks for all the help guys!
07-03-2008, 04:21 PM #15
I bought some plastic epoxy by Loctite. Stuff works great, pretty much fixed the problem!
Thanks for all the help!
I can snap a pic by request if wanted
07-03-2008, 07:26 PM #16Member
- Tulsa,OK
07-03-2008, 10:32 PM #17We'll be back...
- THE SWAMP
I'm late, but I would have told you to use epoxy, too. That problem usually results from using that tab as the lifting point. Most 'mechanics' at tire shops ignorantly think that and quickly roll the floor jack right below and start jackin' away. The tab bends almost immediately causing the plastic panel to bow out in front of the door (unless it breaks like yours did). Some have sworn that it was like that before they started. I've had it happen to two of my Camaros.
07-04-2008, 07:25 AM #18
The water is rain from today...it looks messy from here but you'd never be able to tell unless you look under the car. It looks to be a very strong hold, but yea only time will tell. If it breaks apart I'll just glue it again
Here is what it looks like from the side
07-04-2008, 08:52 AM #19Member
- Tulsa,OK
Looks great man. Good Job!
07-05-2008, 06:28 AM #20
hoping for 12's
By Poppn in forum Drag RacingReplies: 17Last Post: 07-04-2010, 07:35 AM -
hoping for 12s this year...
By EVIL-LS1 in forum Drag RacingReplies: 40Last Post: 05-26-2010, 04:39 PM -
Awwww. And I Was So Hoping To Get One
By CJREX in forum Political / Debate ForumReplies: 3Last Post: 02-04-2010, 08:59 AM -
hoping someone can help
By purplebat66 in forum Firebird / WS6Replies: 2Last Post: 11-05-2007, 05:52 PM
