    Modesto,California
    seabring silver
    2002 Camaro
    hesitation and black smoke
    I have a strange problem, it's an 01 WS6 with 50k miles. When I take off after I idle for an extended period 5 min or more in heavy trafic or in a packed drive through. The engine hesitates, bogs down and blows black smoke like a carbed engine when it loads up. Then I get an SES light and it clears up and the ses light goes out with in a few minutes. By the time I get to work to hook up the scaner, it shows no codes.
    Feb 2006
    2002 WS6
    If you can borrow the scanner, I would suggest putting it logged mode if possible and driving in the same conditions, hopefully it capture the code for you.
    Other wise it sounds like a metering issue of sorts, could be the maf, O2s or even the TPS sensor.
    Modesto,California
    seabring silver
    2002 Camaro
    Yea, I was thinking the same thing, I'll see if I can barrow the scanner this week
    SATX
    2000 Trans Am
    so your SES Lights up and then doesnt store the code? I thought they stayed for a few ignition cycles. as for your problem it sounds fuel delivery related, any where from Fuel filter, O2 sensors, or Fuel pressure regulator.
    Modesto,California
    seabring silver
    2002 Camaro
    I'm thinking fuel regulator my self.
    Modesto,California
    seabring silver
    2002 Camaro
    Well the car acted up last night and I got some codes. A p0200 injector circut open, P0307 cylinder 7 missfire and P0300 randome/multiple missfire detected. I think p0300 and p0307 are a result of p0200. Segestions on the p0200 repair apiciated. thanks
    Senior Member
    Jacksonville, FL
    I'd look them up at gearchatter - here's P0200: www.gearchatter.com/viewtopic9367.php
    Modesto,California
    seabring silver
    2002 Camaro
    thanks I'll check it out
  1. black smoke dodge
    By 04yellowjacket in forum Kill Stories
    Last Post: 03-19-2016, 06:51 PM
  2. Help: Black smoke
    By FIREHAWK0078 in forum General Help
    Last Post: 08-20-2012, 08:41 AM
  3. Question: black, gray, and blue smoke
    By ricekiller65 in forum General Help
    Last Post: 05-26-2009, 12:38 PM
  4. Black Smoke
    By ananmech in forum External Engine
    Last Post: 06-03-2008, 02:22 PM
