Thread: headlight lens
    missouri
    1999 camaro convertible
    headlight lens
    i have read the other threads on the cloudy headlights. my question is how do i get the lens seperated from the light? i have taken the light out and the clips off. the lense wont budge. any suggestions?
    Member stephen02ws6's Avatar
    Dalzell, Illinois
    red with black stripes
    2002 Trans Am WS6
    i helped one of my friends fix his headlights on his mustang. his were all cloudy. what we did was wet sand the outside and then polished it with my buffer and polishing compound. it made a huge difference. cleared them up nicely. i would recomend trying that before taking the headlights apart.
    Member Speed Psychosis's Avatar
    Virginia
    98 T/A M6 w/lid and LM1
    cloudy like fogy/moisture? if so, my friend had that with his tails on his rx8. drilled a few holes that werent noticeable and never had a problem again.
    if not that, its outside so wetsanding them would make them look new again.
    USA
    BLACK
    Z/28 LS1
    Quote Originally Posted by mthorn View Post
    The cloudy haze isnt on the inside of the lens-its actually on the outside. I thought the haze was inside as well when I first looked at mine. Best way to make them look new again is wet sanding, 1500 then 2000 grit. Then polish them with aluminum wheel polish. They make a product to seal the plastic when you are done so they stay looking new-without that sealer they will haze again in a few months.
    Member WS-6's Avatar
    Feb 2008
    NW Indiana
    2000 T/A WS-6
    They are sealed with a type of silicone ruber they will come apart but you have to carefully cut the silicone with a razor blade and gently pry them apart. You can easily break them though so take your time and start one point and work your way around the light, however I would not reccomend donig this unless all else has failed.
    USA
    BLACK
    Z/28 LS1
    I have read several times if you want to take yor headlights apart you need to bake them in a ovem for 20 minutes-not sure on the temperature- look for the "whistler mod" and it will tell you the proper temperature.
  1. 3M Headlight Lens Restore System
    By 1MileCrash in forum Appearance Section
    Last Post: 03-20-2009, 10:29 AM
  2. Corner lens help!
    By GungHoPopsicle in forum Appearance Section
    Last Post: 03-30-2008, 06:08 PM
  3. Front Lens Repair/Lens Color Change
    By matthewaqui in forum Firebird / WS6
    Last Post: 12-02-2007, 06:57 PM
  4. headlight lens
    By lsave in forum Showcar and Detailing
    Last Post: 08-26-2006, 08:55 AM
  5. Clear lens
    By txff636 in forum Appearance Section
    Last Post: 02-12-2006, 02:27 PM
