Results 1 to 16 of 16
    Member DADillac's Avatar
    IL
    98 Camaro Z28
    went to track today it sucked!!!
    why was i so retarded to go and race with my shitty ass street tires?? i was running 13.40@106 and that was with 2.2 and 2.4 60s, on the bright side i was the fastes N/A f-body there, most were running 13.8-14.2 and the stock vettes i went with were running 13.6-8s so i guess i didnt do that bad but a year ago i ran 13.00@107 and since then i got a tune and LCAs, brackets and shocks.
    i was really hoping for 12s, guess i should have brought my ET streets with. time to regroupe, and ill prepare bretter for next time in 2 weeks. gonna clean my dirty ass air filter, get a beefy rear end cover and run the ET Streets. think ill see high 12s then?
    Member tomsws6's Avatar
    delaware
    Quote Originally Posted by DADillac View Post
    man i had the same 60ft's and times/traps!
    You think you are bad on street tires????
    I wish I had video....
    Fort Benning, GA
    '91 turbo fox, '97 vette
    I think you've got 12s in that thing easy with stickier meat. A 3 tenth improvement in your 60' and 12s are a done deal.
    High Point NC
    MGM
    Pontiac G8 GT & 99 Z28 6M
    106MPH is an easy 12.75, just keep trying you'll get it.
    Member bertt23's Avatar
    Jun 2006
    east houston
    pewter
    2002 camaro
    i ran 13.1@114, with good traction what should i be running?
    delaware
    atleast a second faster. what was your .60ft?
    Drag racing is a disease! RacerBob's Avatar
    Feb 2008
    Youngstown, Ohio
    Maroon
    2000 Z28
    M6 or A4? I have an A4 and I was able to get consistant 1.989 60' with my slow a$$ car. What psi? I ran 20 in my Eagle HPs (16"). I can't say what the difference was when I went to the ET Streets because the torque convertor went in same time. I went with the 28 x 11.5 R 16. Mine seem to like 18psi.
    Drag racing...just another numbers game.
    Vortech Super Charger, 9" w/4.11, 3200 Stall, BMR SFC, BMR TracPak, !MAF screen, 160 T-Stat.
    High Point NC
    MGM
    114 is usually good for 11.70-12.00 depending on 60ft/traction. I've ran 113 with a 1.90 60ft and cracked off 11.90. So with a 1.80 a 11.70 should be possible. Sometimes if you have a automatic with a converter that soaks up the power then a 114 might be 12.20.
    Jun 2006
    east houston
    pewter
    2002 camaro
    my best was [email protected], 60' 2.276, i know the car has more to it, but the tires arent all that good, need some new ones, ive only had it for about 2 weeks, it was already modded and have no clue on what it has other than cam and lt headers no cats/mufflers, oh its an a4.
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Quote Originally Posted by bertt23 View Post
    A couple ?'s are you driving through the water box?
    Also are you doing a smoky burnout?
    Are you loading the car by bringing it up on the converter or stabbing it from a idle?
    Member silverz28camaro's Avatar
    Washington MO
    sebring silver
    2000 z28
    11.9
    2000 auto camaro
    13.54 @ 104 2.049 60' stock 2.73
    12.94 @ 109 2.002 60' full exhaust, lid, tune, nitto 555r 2.73
    11.899 @ 114.44 1.686 60' full exhaust, lid, tune, nitto 245/50-16 555r 3.73 moser 12-bolt 2800 fuddle, ls6 intake manifold, slp under drive pully,fiberglass hood, bmr k-member
    Jun 2006
    east houston
    pewter
    2002 camaro
    Quote Originally Posted by LS2Tuner View Post
    yes i go through the water box, and just a very brief burnout. i rev it up to about 3000rpm. dont know if it has a stall or not.
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Well first off that is your biggest problem!!!
    NEVER DRIVE THROUGH THE WATER BOX WITH ANY STREET CAR THAT HAS STREET TIRES!!!
    Water get caught between the tread of ALL the tires and runs out as you go down the track causing more tire spin.
    Your regular street tires DON'T like heat!
    Drive around the water box then just back up a few feet. Stopping before the water and just do a light spin to clean the tires off and warm slightly.
    I would dump it at 5000 and right after you pop the clutch up push it right back in and roll up to stage. All you want to do is a light haze. If you were
    doing a burnout and seeing smoke you put WAY to much heat in them which caused more spin.
    Well since you said 3000 rpm I guess it a 6 speed. That is on the high side (rpm) for a regular street tire.
    Jun 2006
    east houston
    pewter
    2002 camaro
    no its an a4, but i step on the brake and accelerate when the light goes green i floor it and let off the brake. looking for tires right now but wow too expensive it has the z06 rims 295/35-18 in rear and 275/40-17 in front.
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Yeah that huge meat you have in the front is what we normally run in the rear.
    It definitely tracked a nice amount of water since you drove through the water box.
    BFG's are about your only option.
    http://store.summitracing.com/partde...5&autoview=sku
    Nitto's 18 isn't worth a fuck in my opinion.
  1. Track today!
    By dethinboots in forum GTO
    Last Post: 02-12-2013, 10:05 PM
  2. Replies: 6
    Last Post: 11-24-2009, 11:05 PM
  3. went to the track today...opening day
    By 2kbluws6 in forum Drag Racing
    Last Post: 04-07-2008, 03:24 PM
  4. took the 98 to the track today 2/18
    By 98 4mula in forum Drag Racing
    Last Post: 02-18-2008, 06:20 PM
  5. RS track day today results
    By silverz98 in forum Southern Members
    Last Post: 10-25-2006, 04:34 AM
