    N/A nitrously aspirated stangslayer98's Avatar
    miami,fl
    1998 trans am
    power antenna motor stuck
    the other day i heard it grinding when i turned the radio on and off, so i ended up pulling the power off, i have seen motors going for as much as $100 on ebay, but im looking for a smaller non-telescopic antenna.......any ideas?
    Colorado
    Mystic Teal/Chameleon grn
    1998 TA
    mine does the same thing. Sounds like the motor is catching on something. Seems like it wants to go up but something inside the housing is keeping it in.
    Member vannatte's Avatar
    Noblesville, IN
    1998 Pontiac Trans Am A4
    Review this link for the best repair options (assuming the motor still works and the mast is broken). The antenna mast is ran up and down with a set of plastic gears that eventually break or wear down and it just needs replaced (sounds familiar to anyone with headlight issues):
    http://www.ls1.com/forums/showthread.php?t=65117
    I found that my link from the old thread doesn't work. Here is a newer listing on Ebay:
    http://cgi.ebay.com/ebaymotors/_Othe...m370057856151&
    Here are the install instructions:
    http://www.antennamastsrus.com/Instructions%20Mast.htm
    1998 Trans Am, A4, SLP Loudmouth I, US Exotics WS9 ram air hood, Volant intake, 3.23's, 70k miles
    Marylandistan
    2001 Trans Am (sold)
    Check inside the fender and make sure it hasn't been bent while removing the spare possibly.
    Allen, TX
    2001 Trans Am
    i just switched to a fixed mast antenna and got a shorty antenna to put on it
    Member jujofields's Avatar
    Lafayette, Indiana
    Pewter Metallic
    2002 Trans Am WS.6
    Quote Originally Posted by vannatte View Post
    In case it's not just the mast only, that same company sells an entire assembly (including motor, mast, wiring, hardware, etc.) for basically the same price as just the mast:
    http://www.antennamastsrus.com/GM/Po...01993-2002.htm
    miami,fl
    1998 trans am
    cool thanks im gonna go tinker with the motor now that i saw that diagram, if i cant fix it by opening it then im just gonna go with a fixed mast
    Noblesville, IN
    Once you take the motor out, just shave of the plastic rivet heads with a box cutter to gain access to the motor housing.
  1. Replies: 5
    Last Post: 10-30-2013, 09:01 PM
  2. power antenna
    By coolz28 in forum Stereo and Electronics
    Last Post: 07-05-2009, 09:56 PM
  3. Convert power antenna to fixed antenna
    By Red 99 T/A in forum Firebird / WS6
    Last Post: 01-24-2009, 10:40 AM
  4. pitbull stuck in motor
    Last Post: 05-08-2008, 06:18 AM
  5. Antenna motor making noise
    By indiana hawk in forum General Help
    Last Post: 06-10-2006, 10:04 AM
