Results 1 to 10 of 10
Thread: Where to Launch!!
06-10-2008, 09:09 AM #1Awaiting Activation
- Dec 2006
- RDU
NBM- 2002 Camaro Z28
Where to Launch!!
I have a 2002 Z28, just got done installing pacesetter LT's, NGK TR55 Spark plugs, TSP True Duals w/sweet thunder mufflers, and a K&N Filter... and has NOT been tuned.... Im thinking of taking her to the track this thursday for the local test n tune night.. I was wondering where everyone thinks would be the best place to try to get her to launch... i was thinking maybe right around 2000-2400 RPMs...
06-10-2008, 12:52 PM #2
I'm assuming this is a 6 speed car??
06-10-2008, 12:58 PM #3
tires? live and learn, its tough to say. Have fun, (is that a stock 10-bolt?)
06-10-2008, 01:23 PM #4Member
- Oct 2005
- Eastern, Kentucky
Black on Black- 2000 Trans Am M6
If its a 10 bolt be easy lol
SLP LT's, SLP High Flow Cats, 3" Flowmaster CB, Comp Cam, SLP Lid, LS6 Intake, BBK 80mm TB, SFC, Ram Air HO Hood, Lowered, Torq Thrust II's
06-10-2008, 11:00 PM #5Awaiting Activation
- Dec 2006
- RDU
yeah its the stock rear end.... i know i need to change it, thinking about the Moser rear when i get some more cash.... It is the 6 speed... still unsure whether i should run it or not!!
06-10-2008, 11:02 PM #6Awaiting Activation
- Dec 2006
- RDU
I actually tried to launch it earlier today on the way home from work, and for some reason when i shifted from 2nd to 3rd, it was like i was in neutral, the rpms kept climbing but i went nowhere! thinking maybe i need a new clutch?! it is stock tires too!
06-11-2008, 04:30 AM #7
06-11-2008, 06:26 AM #8Awaiting Activation
- Dec 2006
- RDU
I was thinking maybe the synchros or clutch, but i can give it a try
06-11-2008, 08:08 AM #9
To answer your question.....simply try a bunch of different things to see which works best for your car on that given day/night. There are many factors that effect traction: temps, track prep, etc.
Generally, most of the guys running bolt on M6 cars on street tires and the stock 10 bolt find that 1500 - 2000 is the sweet spot. That's usually enough to get you off of the line without bogging down or roasting the tires.
Regarding the clutch....if you still have the stock clutch, welcome to the "my stock clutch stinks" club! We've all had to deal with this at one time or another. Many folks have remedied this problem with the "drill mod"....check out installuniversity for the instructions. Alternatively, I simply threw in a LS7 clutch kit and that fixed the problem.
06-11-2008, 11:22 AM #10Awaiting Activation
- Dec 2006
- RDU
Thanks for all the advice, I think im going to end up going to the track tomorrow, but just to spectate until i get a new clutch and rear end.
launch
By Ls1m6Nichols in forum Drag RacingReplies: 17Last Post: 11-14-2010, 10:15 PM -
Launch pic
By 02blkws6 in forum Member's RidesReplies: 26Last Post: 05-25-2010, 03:25 PM -
Launch RPM's
By baseballguy in forum Camaro / SSReplies: 5Last Post: 09-30-2007, 08:57 AM -
Best way to launch...
By Whiteboycntdnce in forum Drag RacingReplies: 5Last Post: 05-19-2007, 04:51 PM -
How to launch wanting good times but not tearing up the car on launch?
By ErikElvis in forum Drag RacingReplies: 22Last Post: 11-26-2006, 08:54 PM
