Page 1 of 3 123 LastLast
Results 1 to 20 of 42
    San Antonio Tejas
    1998 Camaro SS
    Cool Billet Fuel Door install ques
    Anyone done the mitsubishi Fuel door replacement lately? I just got mine had it painted and I am planning on installing..but would like to get some more detailed instruction on just how it attaches....I read a thread from a long time ago but it really lacked a lot of detail..any help would be appreciated. Thanks.
    Member toxik iroc's Avatar
    s.s. md
    1987 chevy camaro
    mo
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    I think It is just a lot of drilling out the rivets and bolting them in. I always thought it looked good and would look damn fine painted black.
    eBay aDdict™ blindxeyed's Avatar
    Jacksonville, FL
    Sebring Silver Metallic
    1995 Pontiac Firebird
    Saved these instructions a while back. They're not mine, and I would give credit to the person who made them, but I can't remember where I came across it.
    Its fairly straight forward
    You'll need some washers that are ~1/4 - 3/8 in OD...and that fit the bolts that came with the new fuel door.... you'll use them to sandwich your new door and the car body together....
    You'll find it easier too if you remove your rear tire and wheel and loosen up the black body panel inside your wheel well...it just has some plastic screw keepers
    1. Open your fuel stock door...you'll see some pop rivets that circle your door...get a drill that’s just barely larger than the size of the center of the pop rivers... and drill them out..
    2. Pull the door off
    3. If your going to re-use your plastic overfill catch thingie you’ll have to mod it by notching it where the screws on the new fuel door will pass thru it and notch it or drill out holes for them to pass thru... if your not going to re-use then proceed on to step 4.
    4. Press the new fuel door against the outside of the cars body…. and at the same time place the bolts that came with the fuel door thru the holes on the fuel door...and thru or around the catch cup if you used it… they will not need to go thru the body of your car. in fact I don’t think they even come close..
    Anyway...use the nut and washer to "sandwich" the body of the car between the washers and the fuel door. Don’t over tighten so that you can make minor adjustments for fit as you go.
    5. Do the same for all bolts on the cover put everything back.. then check the fit and tighten everything down
    6. Have a beer...your done
    This took me about 35 minutes..its very straight forward....If you do a neat job at drilling out the stock fuel door you can very easily roll-back your mod to stock...
    s.s. md
    1987 chevy camaro
    Does anyone have any pics of this?
    Beaver Dam KY
    79 T/A -91 Firebird
    I do.. give me a sec and Ill edit this.
    EDIT
    Aug 2006
    Oceanside,CA
    SOM
    01 Camaro SS
    I was going to do this to my car when i first bought it,but didnt flow with my color.
    Beaver Dam KY
    79 T/A -91 Firebird
    Powdercoat that bastard SOM
    s.s. md
    1987 chevy camaro
    thanks buytdo you also have a pic from farther back to see the whole car with it
    San Antonio Tejas
    1998 Camaro SS
    Billet Fuel Door
    Thanks everyone! Got it installed was not as difficult as I thought..in fact I did not even have to jack car up or take off rear wheel just reached thru open fuel door to attach washers..tightened..ready to roll!
    I will post pics...I had mine painted black, same color as my car...left the hex headed screws billet....looks real good!
    Tron
    s.s. md
    1987 chevy camaro
    would this work on a 3rd gen (1987 iroc) and how much would this cost?
    Member squee's Avatar
    Baton Rouge
    2000 SS M6
    I think the fuel doors are about $80 but I don't think it would fit the curves (or lack there of) on the 3rd gen.
    COTM July '09
    Annapolis, MD
    BLK/BLK w/CGM Stripes
    2010 Camaro 2SS/M6
    NICE! Can we have some pics zoomed out so the whole side is visible? Maybe something I would look into doing. Mine is white so even keeping it in the original finish wouldn't be too bad.
    The Devil You Know!! TooFastT/A's Avatar
    Colorado
    1998 Trans Am WS7
    Here you all go:
    1998 WS7 T/A M6| SLP:Lid,Line Lock,LM Exhaust w/ORY,Skip Shift| Pacesetter LT| 80mm BBK TB| Centerforce LS6 Clutch| Eaton Detroit TrueTrac Differential| MAC Diff.Carrier Girdle| 3:73 Gears| Spohn Cntrl Arms| Hotchkis Adj PHB| H&R Lowering Sp.Springs| NX 150 Shot Direct Port|More Mods... FQuick Page
    Aug 2006
    Oceanside,CA
    SOM
    01 Camaro SS
    did you do the ls1 front clip on that ta? just wondering if its the same one as the one in your sig.
    Colorado
    1998 Trans Am WS7
    No thats not my car....just posted up a pic from the guy who owns this car's website! People wanted to see a pic of the Fuel door zoomed out...well, I posted a pic!
    Aug 2006
    Oceanside,CA
    SOM
    01 Camaro SS
    Quote Originally Posted by TooFastT/A View Post
    Here you all go:
    it looks like my old t/a
    We don't own imports....
    Colorado
    1998 Trans Am WS7
    If your T/A looked like that....what happened to it??
    Also, the guy whom owns that T/A has the same Blue LED setup on the Rear Backups like mine:
    This is mine:
    and his:
    -Justin
    Junior Member BirdFlewLS1's Avatar
    I sleep in the house...Live in the shop
    midnight Blue
    '99 Trans Am ws7
    Yeah I just seen a civic with the same blue lights last night at walmart....looked SHHEEWWWT
  1. Question: Billet Aluminum Fuel Door
    By KITT#42 in forum Firebird / WS6
    Last Post: 02-20-2010, 07:16 PM
  2. Help: I need a part # for the Billet Fuel Door
    By 1 TRANS AM in forum Appearance Section
    Last Post: 07-31-2008, 08:55 AM
  3. billet fuel door?
    By SSclint01 in forum Appearance Section
    Last Post: 12-04-2007, 10:56 PM
  4. Billet alloy fuel door info.
    By wicked illusions in forum Appearance Section
    Last Post: 09-11-2005, 01:07 AM
  5. Can any body tell me how to install a billet fuel door?
    By wicked illusions in forum Western Members
    Last Post: 09-05-2005, 07:25 AM
