Results 1 to 20 of 27
Thread: Trans Am Automatic Shift knob?
06-09-2008, 04:40 AM #1
Ok, so I guess since the 3rd generation, all automatics get this t-handle.
My question is, can it be changed? I've seen pics of new knobs that look like manual ones, but isn't there a push-to-shift button, when going from Park to anything else?
Sorry for my ignorance,
Dylan
06-09-2008, 06:47 PM #2Junior Member
- Nov 2005
- San Antonio Tejas
black- 1998 Camaro SS
I have a 98 SS and I switched out my auto console for a six sppeed console...I also took off the stockl handle and cut threads on the auto so a hurst T-Handle can screw on, when I do this ..it pushes down and keeps the lockout disengaged...the only prob with this set up is that you cannot drop dopwn into 1st or 2nd...doesnt bother me cause i dont tow boats or trailers and if yiou go to the track it is more effective to leave car in 3rde of 4th anyway..alos you need to be careful not to drop into rverse by accident, hhowver, you would really have to be a numnut if you did this...
Tron
06-09-2008, 06:48 PM #3Junior Member
- Nov 2005
- San Antonio Tejas
Man I guess I should have spell checked! looks like I just fell off the turnip truck!
06-09-2008, 08:22 PM #4
Maybe my question was ambiguous, thanks for the reply though.
Basically all I want to do is change the knob, not the entire console.
So instead of a T-handle, it will be a ball, or some sort of knob, with the same console. But since the t-handle has the push to shift button on the left, will that effect anything?
06-09-2008, 09:30 PM #5your parts guy!!!
- cleveland ohio
trans am 00 ws6- 1998 camaro ss vert
mba was the company that makes them. they are out of business but you can find them. afterthoughtcom i think still has them. you need the one with the "tail" and they have the conversion kits also. pm me if you need some more info.
06-10-2008, 02:34 PM #6Junior Member
- Nov 2005
- San Antonio Tejas
Shift knob
I also did this on my 94 Z28 auto..did same thing removed stock shift knob took a dye cut the threads for the Hurst shifter..this would also work with a ball shifter etc..just need to be slow and careful when screwing on so you don strip the threads you just installed on your stock auto shifter...using auto console you shift just as yoou normally would just wont have lock out..if lock out is important then you might need to look for different solution.
06-10-2008, 02:46 PM #7
1fastcamarosss11 is right, MBA is out of business now, I got mine through them before they went under, but now Thunder Racing picked up their stuff and is now selling them.
same stuff, just under the Thunder Racing name.
1998 WS7 T/A M6| SLP:Lid,Line Lock,LM Exhaust w/ORY,Skip Shift| Pacesetter LT| 80mm BBK TB| Centerforce LS6 Clutch| Eaton Detroit TrueTrac Differential| MAC Diff.Carrier Girdle| 3:73 Gears| Spohn Cntrl Arms| Hotchkis Adj PHB| H&R Lowering Sp.Springs| NX 150 Shot Direct Port|More Mods... FQuick Page
06-10-2008, 05:04 PM #8
Does anyone know where to get the adapter for the 2.25 knob with tail?
06-10-2008, 05:18 PM #9
Did you check Thunder Racing??
06-10-2008, 05:25 PM #10
Yep, I couldnt find the adapter.
06-11-2008, 08:18 PM #11Member
- Nov 2006
- Hammond, Louisiana
Collector Yellow (54U)- 2002 Trans Am CE
The MBA knobs aren't the only ones to choose from. You would be surprised what might fit. If any of your friends or relatives have nice auto vehicles, check to see if their knob might work.
I got tired of my T-handle being all worn looking and Actually found that a 2005 Thunderbird knob works great and still looks like stock. (which I like, but not many go for)
Check it out here:
http://www.ls1.com/forums/showthread.php?t=592922002 Trans Am Collector Edition WS6 ASC# 619
Coupe | Collector Yellow on Ebony Leather | A4 | TCS | #126 of 510 T-Top w/A4 made
CETA 619 "The Falcon"
Collector Edition Owner Site: www.collectorfbody.com
06-11-2008, 09:04 PM #12
06-12-2008, 08:13 AM #13
Does anyone have more pics of MBA or any other after market knob installed?
06-12-2008, 10:08 AM #14
I know I don't have an auto, but here's my MBA shift knob:
06-12-2008, 10:17 AM #15
06-12-2008, 01:55 PM #16
06-12-2008, 08:48 PM #17Member
- Jun 2007
- Dalzell, Illinois
red with black stripes- 2002 Trans Am WS6
try ws6 store thats were i got mine from
06-13-2008, 05:08 AM #18
06-15-2008, 08:19 PM #19eBay aDdictâ„¢
- Sep 2006
- Jacksonville, FL
Sebring Silver Metallic- 1995 Pontiac Firebird
Grand Prix shifter and boot:
Direct swap, no modifications needed.
06-16-2008, 12:51 PM #20Junior Member
- Nov 2005
- San Antonio Tejas
shifter
I think you can buy any of the universal B&M or Hurst shifters and they come with several adapters..that is what I used to install my hurst T-handle onto my auto shifter.
Will an automatic shifter knob from a cts fit a Trans Am?
By 98TransAmWs-6 in forum Appearance SectionReplies: 2Last Post: 09-29-2011, 01:00 PM -
Automatic shift knob
By PHXLB in forum Firebird / WS6Replies: 31Last Post: 02-26-2010, 04:38 PM -
Automatic Shift Knob
By GULLETT17 in forum Appearance SectionReplies: 9Last Post: 03-17-2008, 08:06 PM -
WTB: Stock Trans am Manual Shift Knob
By 6speedTAthistime in forum Parts Wanted / TradeReplies: 1Last Post: 11-01-2007, 06:25 PM -
automatic shift knob NEW STYLE
By greatwhiteZ28 in forum Appearance SectionReplies: 11Last Post: 03-31-2007, 01:10 PM
