Thread: 6.0 Iron Block
    Simpsons Did it!! 98formy's Avatar
    Minnesota
    83 Z28 new project
    98 Formula WS7-sold:(
    6.0 Iron Block
    Is a iron block 6.0 out of a truck a good block to use in a f body to replace the aluminum? I would replace the whole top end(heads/intake/cam) with the parts off my ls1 that are good. Would they work and is it worth it because I can get the whole motor for pretty cheap.
    Retired Outlaw Sum Bitch
    LQ9 is what you are after.
    Member Speed Psychosis's Avatar
    Virginia
    98 T/A M6 w/lid and LM1
    why would you want to replace the aluminum with iron? could alter handling...
    The block you mention (6.0 LQ9) will take your LS1 parts. You may have to drill and tap one bolt hole for your alternator.....
    Quote Originally Posted by Speed Psychosis View Post
    My swap reflected a 70lbs difference. You go iron for boost/higher HP applications....no cylinder flex....
    old timer blue02Z's Avatar
    2002 Z28
    yep, not to mention its the base for the 402/409 witch yeilds unGodly amounts of hp. isnt that what you runnin Sarge?
    Yeah....just crazy torque.
  1. Iron block LQ4 vs. LS2
    By Jay37 in forum Internal Engine
    Last Post: 11-18-2010, 11:17 AM
  2. Iron Block
    By WonFastWS6 in forum Suspension and Handling
    Last Post: 11-05-2010, 11:30 AM
  3. FS: 6.0L Iron Block
    By HotRodV6 in forum Parts For Sale / Trade
    Last Post: 11-18-2005, 06:36 PM
