    Member barryz's Avatar
    roosendaal , netherlands
    2000 transam ram air WS6
    adjustable lowering springs
    http://www.ws6project.com/user_stor/...e052f0d02e6a47
    are these adjustable springs any good ??what all do i have to change to put these springs in thanks a lot for the information
    grtz barryz
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    they are great.
    I have a set of those, fwiw.
    you just need to mount the coil-over hat on the front shock and the rear is a piece of cake.
    If you were to go ahead w/ these springs, you have to chose your spring rates... now that brings me to the question of what you want to do w/ your car ?
    You like stiffer springs/ride ? not talking about harsh (harshness is when springs/shocks mismatch).
    The fronts spring rates go in increments of 50 lbs/in, and the rear ones go in increments of 25 lbs/in.
    I have 500/150 spring rates, fwiw.
    Also, what shocks will you be running with those springs ? the most important part is to have shocks that match the spring rate of your choice... otherwise, you're shooting yourself on the foot.
    Which swaybars you using as well ?
    Eugenio_SS
    i didn't know you could order these springs in different rates ?!!!
    i have the stock ws6 suspension i just wanna lower it because i have a gap between my new wheels and the fender i have 20' neeper moxy rims a wanna lower my car as much as possible .
    i also hear people you need to get a wheel allignment after this is that true??
    thanks a lot greetings barry
    Jun 2002
    Montreal, CANADA
    triple-black
    you will need an alignment.
  1. UMI Adjustable Panhard Bar and Strano Springs
    By Naaman in forum Parts Review
    Last Post: 02-27-2014, 07:32 PM
  2. adjustable springs??
    By yahelou in forum Suspension and Handling
    Last Post: 11-25-2006, 08:58 AM
  3. 1LE with Koni adjustable shocks and lowering
    By 981LEZ28 in forum Suspension and Handling
    Last Post: 02-07-2006, 05:47 AM
