    Member 99transamC/FIA's Avatar
    Jun 2006
    DETROIT
    PEWTER
    99 TRANS AM
    Wiil truck oil pan fit f-body k-member
    Will a oil pan off a ls series truck fit in a stock k-member 98+ f-body.
    What is the difference in the two?
    TN
    2005 GTO M6 Black
    2000 Z28 A4 Red
    No there is a huge sump on the truck pan.
    Gold Member BlwnCamaro's Avatar
    Las Cruces,NM
    1998 Z28 Camaro
    +1 No. I have 6.0 truck pan drops way low have to have fbody pan .
    Member jujofields's Avatar
    Lafayette, Indiana
    Pewter Metallic
    2002 Trans Am WS.6
    I know you can buy some aftermarket oil pans that are larger though....specifically to keep a high volume of oil in the car when getting on the gas, etc.
    Arizona
    I was thining the truck pan does in fact fit the F body K-member just fine,,,,,,is this not the original posters question????
    Only difference is the deeper sump,,,but it still fits the F-body K-member,,,,,correct???
    Ground clearance has nothing to do with whether it fits the car or not....unless some kid got ahold of it and slammed it on the ground. but that still doesn't pertain to the question per say.
    Jun 2006
    DETROIT
    PEWTER
    99 TRANS AM
    Ground clearence is not a problem.i got a 5.3 out of a truck for free and,I'm wanting to put it in a 95 car.
  1. New Member/Truck Info
    By navygunz1 in forum Member's Rides
    Last Post: 12-14-2010, 04:40 PM
  2. W. Houston Member LS! and Shop Truck
    By RyanJM in forum Texas Members
    Last Post: 06-24-2009, 05:56 PM
  3. Looking for 6.0L truck intake/throttle body/injectors/etc
    By kst8engineer in forum Parts For Sale / Trade
    Last Post: 03-18-2006, 09:27 PM
  4. Will Truck Throttle Body Work? Worth It?
    By JoeMack in forum General Help
    Last Post: 02-03-2006, 12:54 PM
  5. 4.8L Truck throttle body swap
    By speed01rcr in forum External Engine
    Last Post: 10-23-2005, 02:09 PM
