Results 1 to 2 of 2
Thread: Spun Bearing?
    BAMF
    Guest
    Spun Bearing?
    My name is Brent and I'm new to the board, my problem is that I have a '01 LS1 Z28 and in the cold weather of saskatchewan the oil press has dropped to 10 psi and there's a growling noise coming from the motor, do I have a spun bearing? or could the oil pump be fucked?
    Saskatchewan
    1998 Camaro SS
    Brent I have been thinking anout this.........
    If it were a spun bearing, you engine would knock, not growl. It would knock louder under acceleration, and would knock once per revolution (assuming it is only one bearing).
    So, since you say growl, i would seriously consider looking else wear in the engine.
    Does the growl get louder with higher rpms? If so, pull the oil pump. Consider the LS6 oil pump for replacment.
  1. Help: Think I spun a rod bearing!!!
    By yanoZ28 in forum Internal Engine
    Last Post: 10-28-2009, 06:16 AM
  2. LS1 Spun Bearing
    By 02silverado in forum General Help
    Last Post: 04-19-2008, 04:34 AM
  3. Spun a rod bearing
    By Fire Chicken of Doom in forum Western Members
    Last Post: 02-26-2007, 10:33 PM
  4. How to tell if you've spun a rod bearing.
    By nc98z in forum Almost Anything Goes
    Last Post: 08-23-2006, 10:49 AM
