    Royal Oak, Michigan
    2004 GTO A4
    The Correct Way To Inspect The Strut Bearings
    Does anyone have the correct way to inspect the strut bearings? I have this damn shake from 70+ that won't go away. I have checked or replaced everything and have not had any luck getting it to stop.
    Member Tide's Avatar
    Southeast
    Nothing special
    Nothing special
    Jack it up on jackstands to free up the front wheels, with the steering wheel locked, give the wheels a good tug. Any looseness, slack, or play?
    Retired Outlaw Sum Bitch
    Open your hood....rock your car back and forth and look to see if the strut bushings move.....
    Southeast
    Nothing special
    Nothing special
    Or simply, that too
    Royal Oak, Michigan
    2004 GTO A4
    Wow Sarge, you know a trick for everything. This makes me think that you have done a lot of work to your suspension
    Got that right....As I mentioned when you first started this shaking thread.....I bet it is the strut rod bushings/radius rod bushings ( front and rear).....hell you can never balance shit when those POS OEM bushings are allowing your wheel to wander all over hell and back...
    Jan 2008
    West Michigan
    Quote Originally Posted by surfinjoe View Post
    Have you replaced the factory strut mounts?
    Indianapolis, IN
    All Black
    83, 87, 02 All WS6 T/As
    Hmm.. I've been fighting the same thing for the last year... just hit 118k.. stock front struts... new CHEAP monroe rear shocks... but aftermarket LCAs, PHR, TQ Arm, steel D/S, 12 bolt, and crossmember. Installed them all at once.. so I was thinking more toward the aftermarket stuff.. What $$ are we looking at here?
    -Geno
    1983 Black WS6 "WindCharger"
    1987 Black WS6 "WS87"
    Sold the other four f-bodies
    Jan 2008
    West Michigan
    It depends one what you want the car to do. Straight line, daily driver, twisties, etc. Do you want rake? Dropped? Just fix the jello they call oe bushes?
    Royal Oak, Michigan
    2004 GTO A4
    Quote Originally Posted by PartsGedder View Post
    I did not replace the factory strut mounts. I would like to know that they are bad before I spend the $$ on them. As I have already said, I have replaced every other bushing that is prone to failure without much results. I would like to determine the root cause before I replace another part.
    I have tried the old shake the car back and forth method. Any other thoughts on checking the strut mounts/bearings?
    Jan 2008
    West Michigan
    You need to remove the strut plate to inspect the mount. Cracks in the inner edges of the mount or an elongated hole where the center ferule is located are good indications of failure. Take a deep 24mm socket and tighten the nut on the mount. It should have some spring back after a 1/4 turn after being fully tightened.
    Royal Oak, Michigan
    2004 GTO A4
    Yea, I tried that but I didn't see any excessive movement. Good news is that because I hit that pot hole, my insurance will pay for the repairs including fixing the shake
  1. How to inspect a clogged fuel filter
    By johngoodman in forum General Help
    Last Post: 03-25-2015, 07:07 PM
  2. Help: ready to inspect rockers..what should i NOT do?
    By DaytonaBlues in forum Internal Engine
    Last Post: 10-11-2013, 02:10 PM
  3. am i seeing correct?
    By jiveass in forum Almost Anything Goes
    Last Post: 01-12-2011, 09:24 AM
  4. Replies: 11
    Last Post: 01-23-2008, 04:16 AM
  5. Correct me if I'm Wrong
    By enjun in forum Stereo and Electronics
    Last Post: 03-21-2007, 02:46 AM
