Results 1 to 10 of 10
06-04-2008, 08:39 PM #1
Replaced Power Steering Pump-Bleeding Question
I replaced the power steering pump today and refilled the reservoir. I have the belt off and the wheels in the air. My manual says to turn the wheels lock to lock at least 20 times to get all the air out of the system. I must have done it like 300 times and there's still bubbles in the fluid.
I turn the wheel like 20 times and watch the reservoir and the fluid level rises to the filler neck, then I stop. I shine a light into the reservoir and see lots of tiny bubbles (Cue Don Ho...)
Should I continue on until there are no more bubbles in there or what? I don't want to put the belt on and start it until I'm sure it's all bled...
Thanks
06-04-2008, 09:09 PM #2
I would imagine that it is good, my power steering leaked before and all the fluid drained out, i put power steering conditioner in it and it stopped the leak. Only a few minutes and the PS was working. but there is still a leak as of now and my tie rod ends are bad. i just ordered the bmr manual rack and will be installing it this tuesday.
How much did your pump cost?
06-04-2008, 09:26 PM #3
I don't remember exactly since I bought a bunch of other stuff at the time. I think it was like $70 at Kragen, but they charge you $50 for the core return...
I guess I'll just keep turning the wheel back and forth until I don't see any more bubbles. It's kinda tiring...
06-05-2008, 03:11 AM #4Senior Member
- Apr 2008
- Madison, WI
no you're good to go. Those tiny bubbles won't hurt. Put the belt on, start it up and if the pump doesn't whine then you're good to go.
06-05-2008, 05:01 AM #5
I just replaced mine and the new pump whines !
06-05-2008, 05:14 AM #6
06-05-2008, 11:05 AM #7
I'm installing my manual rack this tuesday and i will do a little right up on it. I'm sure it will be a little harder to turn at lower speeds but i will save 30lbs and not have to worry about leaky pumps
2000 auto camaro
13.54 @ 104 2.049 60' stock 2.73
12.94 @ 109 2.002 60' full exhaust, lid, tune, nitto 555r 2.73
11.899 @ 114.44 1.686 60' full exhaust, lid, tune, nitto 245/50-16 555r 3.73 moser 12-bolt 2800 fuddle, ls6 intake manifold, slp under drive pully,fiberglass hood, bmr k-member
06-05-2008, 01:19 PM #8
It's all good to go. I installed the belt and started it up with the cap off...
No bubbles! Fluid level good... No more whine...
06-05-2008, 03:44 PM #9
06-05-2008, 04:51 PM #10Senior Member
- Apr 2008
- Madison, WI
If it whines let its possible the fluid got all frothy. Let it sit for a few hours so the air bubbles come out and try again.
Otherwise from my experience, you'll get a lot of bad pumps from NAPA, Autozone, etc. before you get a good one. If there is an option, get the nicest one they have or get an AcDelco pump.
Help: power steering pump
By 98LS6SSCAMARO in forum General HelpReplies: 2Last Post: 03-04-2013, 06:29 AM -
power steering pump question
By oharam in forum External EngineReplies: 11Last Post: 12-03-2011, 10:59 PM -
Bleeding power steering lines
By Lunatikgixxer in forum General HelpReplies: 6Last Post: 10-04-2010, 07:15 PM -
Power Steering pump leak?! new pump or seal kit?
By JehalinTA in forum General HelpReplies: 2Last Post: 03-18-2008, 10:05 PM -
power steering pump
By roadrashr6 in forum General HelpReplies: 1Last Post: 01-01-2006, 07:15 AM
