06-03-2008, 08:25 PM #1Impounded
- Jun 2008
- Garage
- 99 Trans Am WS.6
Do I need to break in my rear end?
I just got 2 new rear shafts for my rear end because my old ones were bent and messed up....Do I have to break these shafts in...although I still dont have a "completely" new rear end?
06-03-2008, 08:52 PM #2
New axle shafts do not require a breakin. That's just for new gears.
06-03-2008, 09:14 PM #3
06-04-2008, 04:59 AM #4Impounded
- Jun 2008
- Garage
- 99 Trans Am WS.6
06-04-2008, 02:12 PM #5
That is a terrible idea. Drive for 20 miles and stop for lunch. Then drive another 20 miles and go shopping. Then drive the rest of the way home.
Below is my suggested breakin for gears. If you don't follow this, you're likely to severely overheat your differential, making your new gears much weaker and possibly causing bearing failure.
Fill with fresh gear oil. Drive for 20 miles without hard acceleration and at a steady speed. Do not exceed 60mph. Let the vehicle sit as long as it takes for the differential to become cool to the touch. Repeat procedure one more time.
For the first 100 miles, do not exceed 60mph. After 500 miles, drain/refill with new gear oil. Your new gears are now broken in.
06-04-2008, 02:12 PM #6
06-04-2008, 02:21 PM #7Impounded
- Jun 2008
- Garage
- 99 Trans Am WS.6
Sweet....thanks man.
If anything happens to my rear end, ill come looking for you
Grinding in Rear... Parking Break ??
By CobraKilla in forum General HelpReplies: 6Last Post: 07-03-2012, 10:25 AM -
Engine Break-In Guide - Break-In Without Breakin'
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 03-17-2011, 09:40 AM -
Yes, Another Will These Tires Break My Rear? (A4)
By Mesterious in forum Wheels and TiresReplies: 2Last Post: 06-30-2010, 03:39 PM -
check out this break dancer break
By pecha in forum Almost Anything GoesReplies: 4Last Post: 02-23-2009, 09:20 PM -
Likely to break the rear at the track?
By jimbo98z in forum DrivetrainReplies: 4Last Post: 11-27-2005, 06:20 PM
