Results 1 to 19 of 19
06-02-2008, 10:30 AM #1Member
- Jul 2007
- Allen, TX
Red- 2001 Trans Am
About to replace headlight motor gears
I got the aluminum headlight motor gears and am planning on replacing them this weekend. The instructions it came with are really good and detailed but I'm still nervous about doing it. How hard is it to replace them? Anything I really need to worry about? I'm gonna take my team and I consider myself good at following directions.
06-02-2008, 11:23 AM #2
its not to bad only took me but an hour from start to finish
06-02-2008, 12:02 PM #3rapter34Guest
where did you get them from?
06-02-2008, 01:44 PM #4
I'm curious too, as I thought the only ones made were brass. Aluminum may not be best, but that's just my gut feeling...I'm sure they are better than the plastic junk that is stock.
06-03-2008, 09:58 AM #5Member
- Jul 2007
- Allen, TX
Red- 2001 Trans Am
I got them here: http://www.rodneydickman.com/retail_new.html
the aluminum are supposed to be just as good as brass just slightly cheaper since prices of brass have went up
06-03-2008, 11:27 AM #6
i used brass also...
06-03-2008, 01:25 PM #7
http://www.bfranker.badz28.com/headlightfix/index.htm
look at the instructions and instructional video here
06-03-2008, 05:01 PM #8
It's not difficult at all. Turn the lights on, unplug them, turn the lights off, remove the trim, remove a few 10mm bolts and the motor slides out. I kept the light propped up with a towel while I was doing the repair. Pop the cover off of the motor, swap gears, slap some grease in there and put it all back together. I hope you got the braces & bumper along with the gears. Mine stopped working within a few weeks since I didn't use the braces. The glue isn't strong enough to hold the cover back on the motor and it pops off. The repair is worthless without the braces. I did this repair on my old 94 T/A, but I think its the exact same repair.
1998 Trans Am, A4, SLP Loudmouth I, US Exotics WS9 ram air hood, Volant intake, 3.23's, 70k miles
06-04-2008, 06:57 AM #9Member
- Feb 2008
- NEW JERSEY
PEWTER- 2001 TRANS AM WS6
What braces and where do I get them
06-04-2008, 07:02 AM #10
They come included in his kit. They are pictured in this link (http://www.rodneydickman.com/retail_new.html). It looks like a cross.
06-18-2008, 10:29 PM #11
i use brass gears on mine then used appoxy* on the covers, worked great. got mine from that guy bfranker
-Half Throttle Racing-
06-19-2008, 05:03 AM #12Member
- Apr 2008
- allenhurst GA
black- 99 formula firebird
will be ordering some of these when i get back..stupid headlight motor
06-21-2008, 01:05 AM #13Junior Member
- Apr 2007
- Indianapolis
Black on black- 2000 Trans Am WS6
That plastic cover was a pain in the ass to get off. I got a nice little cut from that but the rest went real easy. Watch the video, it help out a lot. After I did my driver light I got the confidence to do the plugs and wires. A little over 4 hours for them but it sure was worth it. $400 for a shop or 120$ (parts) and 4 hours at home.
06-21-2008, 01:06 AM #14Junior Member
- Apr 2007
- Indianapolis
Oh ya I got mine from bfranker as well.
06-21-2008, 08:07 PM #15Junior Member
- Feb 2008
- Kingsville, TX
Black- 2000 WS6 A4
I used washers on the passenger side motor bolts just for some added security on the cover. Never can tell how well an epoxy is going to work. Good luck.
06-22-2008, 06:38 AM #16
06-22-2008, 07:23 AM #17Junior Member
- Feb 2008
- Kingsville, TX
Black- 2000 WS6 A4
I used the 3 bolts that hold the motor onto the bracket. Just put some washers on the side with the cover. There will probably be an 1/8" gap between the washers and the cover itself. I just cut up a small piece of plastic I had laying around and super glued it to bridge the gap. When you torque the bolts down the washers should be butted up against the cover then. I only had to do it on the passenger side though because the driver's side cover is pushed up against the bracket. All I did for that side was super glue the pieces of plastic to the cover and the bracket acted as the washers and held the cover in place. Hope this makes sense. If it doesn't I'll try and take some pictures.
06-22-2008, 07:54 AM #18
06-22-2008, 08:25 AM #19Junior Member
- Feb 2008
- Kingsville, TX
Black- 2000 WS6 A4
Sounds good...sweet profile picture by the way.
anybody ever replace a window motor that got stuck down?
By goof4080 in forum General HelpReplies: 5Last Post: 10-30-2013, 09:01 PM -
Wanted: 97 ws6 headlight motor
By Blue Sun in forum Parts Wanted / TradeReplies: 0Last Post: 07-19-2009, 06:17 AM -
Brass headlight gears
By GSXING in forum Firebird / WS6Replies: 3Last Post: 12-01-2006, 07:28 AM -
BFranker Brass headlight gears
By Hurley711 in forum Parts For Sale / TradeReplies: 4Last Post: 08-17-2005, 12:14 PM
