Results 1 to 18 of 18
    Kentucky
    2000 Camaro SS (SLP)
    how to clean brake dust
    in addition to my SS I have a 97' F150 that has a set of Dick Cepek DC-1 wheels that are polished aluminum. As of late I have spent alot more time cleaning the car than the truck. The wheels were absolutely covered in brake dust but I have managed to get the biggest part off but there is still quite a bit in sections that I cant get. I have used different cleaners and a mothers power ball....Any suggestions of things that have worked for you?
    Senior Member Z06-Goose's Avatar
    Colorado
    Avus Silver
    2007 Audi RS4
    What worked in other areas, should work everywhere else. Try a toothbrush to scrub it down. Some products you need to let it soak a little bit before you work it off
    There's a product called P21S Gel Wheel Cleaner that might be what you're looking for. Make sure is the "gel" formula. Do a google search, and you'll see a lot info on it
    I've seen this product used by pro-detailers and it has done a great job!
    Also, a similar product S100 Wheel Gel Cleaner in gel form can be found at almost any Harley Davison dealership. These two products are water-based and will not ruin your wheels...
    New wheels.
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Get some good pads from advanced auto and you wont have brake dust.(thanks orion)
    Junior Member tiny47's Avatar
    Finleyville, Pennsylvania
    Midnight Blue
    2001 WS6 TRANS AM
    Most detailer supplers have a mild acid (wire wheel cleaner). This works very good. However DO NOT leave it on for a long time it may stain your wheels. I have used it for about 10 years with no problems.
    Senior Member GULLETT17's Avatar
    Muncie, IN
    00 TA PWTR, 98 VertTA NBM
    80 TA BLK, 80 Formula NBM
    2000 grit wet sand paper then mothers just finished up my wheels with this a couple days ago. . . they shine better than what they did new
    Junior Member Nauty99SS's Avatar
    greenville sc
    1999 camaro ss
    change pads
    Member Selride's Avatar
    Tallahassee, FL
    Blue
    I've had good luck with using fine steel wool. Just rub very lightly and keep the surface wet at all times! I used eagle-one aluminum wheel cleaner as the lubricant.
    Huntington Beach, CA
    I'd avoid acid cleaners as it will clean, but will require more polishing later.
    An abrasive like steel wool will also get some areas clean, but it won't get in the nooks and crannies, and will probably still require polishing.
    Knowing which cleaners you've used specifically may be helpful, but if you haven't tried Eagle 1 All Wheel & Tire Cleaner (about $6 available everywhere), give that a try. Spray it on, agitate with a soft fine-bristled (or split-bristled) brush to get into the nooks and crannies, and rinse with a strong car wash solution. Inspect and repeat.
    Get them clean and then try polishing them with the PowerBall and aluminum polish.
    If you have pitting, that's another challenge, and brake dust can get lodged in the pits.
    Try those things, and if you need more help please provide a photo.
    Indianapolis
    Black on black
    2000 Trans Am WS6
    How about the inside of the stock wheels? Now that I have got a new DD the TA is going to get the royal treatment like it needs. I tried wheel and tire cleaner and it worked a little.
    Which pads? I am having a really hard time with my front wheels. A few hundred miles and they're nasty!
    Beaver Dam KY
    79 T/A -91 Firebird
    Bendix from Advance
    Bendix from Advance
    I've still got 70% left on the front and 90% on the rear...but, I can't take it anymore!
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Bendix from Advance
    Bendix is no more at Advance!! They now only carry Wagner as their top of the line pad, which are supposedly better than Bendix.
    I would go with Hawk for good performance pads though.
    Veteran Blackbird WS6's Avatar
    van down by the river
    get a power washer that should fix you prob. haha
    USA
    Getting a new pad will solve the problem. Also you can buy a brake dust cover. just my 2 cents.
    ____________________
    Must read: Ride in Style
    Colorado
    Avus Silver
    2007 Audi RS4
    I put sealants on my wheels. If you don't have sealants, just use the same wax you use for your car at least once a month. It will make the job of cleaning brake dust much easeir...
    Member Mike's TA's Avatar
    Austin, TX
    99 Trans Am(sold)
    I used to have horrible stains on mine. No idea how they got there. I tried using a bunch of products and nothing seemed to work.
    Then they came out with the mini.
    I used mothers powerball mini with mothers aluminum polish. Spent about an hour on each wheel. It got them looking new again. The key is to really take your time and use a slow rpm on your drill.
    Not a close up, but gives you an idea:
  1. Question: brake dust
    By 1998 T/A in forum Showcar and Detailing
    Last Post: 02-23-2009, 09:57 AM
  2. Question: $ Affordable $, low dust brake pads?
    By 9t8z28 in forum Wheels and Tires
    Last Post: 03-10-2008, 12:57 AM
  3. Safe NON corrisive, wheel spray for brake dust?
    Last Post: 01-31-2008, 10:13 AM
  4. Need tips on brake dust removal
    By Speedy_Gonzales in forum Showcar and Detailing
    Last Post: 02-09-2007, 09:55 PM
  5. what NO DUST brake pads do you like
    By CitationZ06 in forum Suspension and Handling
    Last Post: 09-02-2006, 02:37 PM
