05-27-2008, 12:06 PM #1tattoo artist,esquire
- Dec 2005
- Huntington Beach, California
navy blue metallic- 2001 trans am
Alpine install,need brake wire color code
Im installing an Alpine cd/dvd/nav unit and its calling for emergency and foot brake connections. Ive looked at the diagram I have and it seems to say the light blue wire is for the foot brake,I hooked it up to that one and it doesnt work. I hooked it up to the orange wire too and that didnt work either.The emergency brake only has one wire so that one seems easy. Thanks for the help.
GMPP LS6 crate motor,racetronix,Wilwood 6 piston,HID's,200mph speedo,full dynomat, GY F1's,17" Y2K, Alpine audio upgrade,3" ele cutout, LT's, catted-Y, full suspension
05-27-2008, 12:12 PM #2
are you trying to hook it up so you can watch movies while driving. If so, you need to hook up toggle switches, one to a 12v, and the other to a ground. I dont remember which is which, but that is what i did so the H/U thinks you have the e-brake on and are stopped. It was on my old jeep, otherwise I'd look at it for ya, have fun, it took me a while to it to play while i was in gear!
05-27-2008, 05:58 PM #3
The orange wire is your supply voltage going to the brake stoplamp switch. THe Light Blue wire gets turned on when you apply your brake pedal. So it's a positive signal.
(Talking about "C1" Grey 2 pin block)
Is the alpine looking for a Negative Trigger?
If so, You'll need to add a relay.
I've got the schematic for a negative trigger...if you need it.
Oh...and double check the fuse to the brakes...you may have popped it if you grounded it out.Last edited by Trickytransam; 05-27-2008 at 06:00 PM.
05-27-2008, 07:43 PM #4
I'm gonna move this to the audio section.
05-27-2008, 08:33 PM #5tattoo artist,esquire
- Dec 2005
thanks,
For the future, the light blue wire next to the orange is the one that the black and yellow wire go to. This is for most Alpine HU and DVD players.
Help! Door speaker neg/pos wire color?
By slimjim1284 in forum Stereo and ElectronicsReplies: 5Last Post: 03-12-2011, 05:08 PM -
color code?
By wickbc in forum Firebird / WS6Replies: 6Last Post: 11-14-2010, 09:37 PM -
remote wire color (stock amp)
By MnLS1 in forum Stereo and ElectronicsReplies: 3Last Post: 03-03-2008, 11:16 AM -
Color Code
By OnEbAdReDSS in forum Camaro / SSReplies: 2Last Post: 01-26-2008, 05:38 AM -
Color Code
By M.RedWS6 in forum Firebird / WS6Replies: 5Last Post: 12-17-2006, 04:47 PM
