Thread: Time for brakes
    WS9 + Y82 = Trans Am 6speedTAthistime's Avatar
    cincinnati, ohio
    02 Trans am
    Time for brakes
    Looking for a good brake upgrade. I want something better than stock, but i dont want to spend 3k on Big Brake Kit.
    Heres what i've narrowed it down to. These are off of the Tire rack website.
    So i'm looking into Ceramic pads, with slotted rotors, SS lines and Blue Brake Fluid. Any input would be appreciated.
    Pads:
    ATE Premium One
    Hawk HPS
    Akebono ProACT
    Rotors:
    ATE Premium Slotted Rotors
    Cryo Stop Rotor
    Lines:
    Goodridge G-Stop Brakeline Kit
    Pony Killer Insert's Avatar
    Mississauga, Ontario, Canada
    2002 Camaro SS M6
    i am using the same ss lines and the hawk pads that you listed, but i am using brembo drilled rotors. I have no complaints, they make a real nice setup, performance is great, and they look damn sharp.
    Member Fastcar's Avatar
    Jersey Boy
    Dark blue metallic
    2000 TransAm
    I got all of my brake components from Tire Rack also. I'm using the Akebono ProAct ceramic pads, the Goodridge SST brake lines, and Brembo blanks (not drilled or slotted). I'm happy with the performance and haven't had a single problem. I'm using Valvoline full synthetic brake fluid, the stuff you can get at any auto parts store. It works as well as the higher priced brake fluids.
    WI
    Blog Entries
    1
    09 EclipseGT 75 Chevy 4x4
    2001 Trans-Am 13 F-XT
    I'm planning on a C5 front brake conversion using Powerslot rotors, Hawk pads, new stock F-body rear calipers, braided lines, SLP line lock kit. I didn't total up a price yet, but it shouldn't be to expensive.
    Member jujofields's Avatar
    Lafayette, Indiana
    Pewter Metallic
    2002 Trans Am WS.6
    As Fastcar pointed out in his post, go for Brembo blanks....no need for drilled/slotted.....also, Hawk pads are a great way to go IMO..
    Allen, TX
    2001 Trans Am
    sounds good to me but personally I dont think the s.s. brake lines are worth it.
    Austin, TX
    2001 Trans Am WS6
    Quote Originally Posted by patriot1136 View Post
    You couldn't be more wrong. Having just installed SS lines, they were worth every penny unless you drive like a grandma.
    Member muteki's Avatar
    May 2008
    Guam
    Electric Blue Pearl
    2001 Trans Am
    I bought some generic cross drilled and slotted rotors off of Ebay that were 'zinc coated' cause it sounded nice. I put them on my V-6 and probably have put 30k miles on it since. That car stops on a dime, but my T/A needs brakes soon so I will do the same upgrade then. If you like, I can look up the seller so you know he is legit.
  1. 1966 El Camino Brakes - Brakes In a Box
    Last Post: 06-06-2008, 10:10 AM
  2. Time for brakes! any recommendations??
    By 28Marcos in forum Wheels and Tires
    Last Post: 09-04-2007, 08:40 PM
  3. doing brakes for the first time
    By jAgZ28 in forum LT1
    Last Post: 02-18-2007, 10:45 PM
  4. Replies: 4
    Last Post: 10-29-2006, 01:44 PM
  5. Time for upgraded front brakes
    By SOMSS in forum Suspension and Handling
    Last Post: 10-01-2006, 03:13 PM
