    retired racer not 4 long chevy1966's Avatar
    mississippi
    red white
    1999 z28 vert 1998 z28 ht
    Fastest pass on stock or modded factory 10 bolt
    What is the fastest pass you all have made with your factory 10 bolt rear. Just trying to see when I need to be worried.
    My best friend was running 11.7s on his 10 bolt with 3:73s, 4000 stall, cam etc. Did so for 2-3 years.
    He added a BMR torque arm, next time out to the track, his 10 bolt blew and took his built 4l60E out with it.
    Painted manta stripe
    mississippi
    red white
    Awright, you are already scaring me, I have just installed 3.73 gears and UMI torque arm with relocater. Have always had a 3200 tci Streetfighter. Best run so far was mid 11's with 170 60' time sprayn 125. Want to know how much more it can take. I was hoping for a real low 11 with the factory rear end since I have changed gears and added mac mid tube with ory since last time out.
    Quote Originally Posted by chevy1966 View Post
    I believe you are on borrowed time. We were both pretty sure it was the torque arm that killed his rear, there is no give with the aftermarket torque arm in there. He was cutting 1.6s and 1.7 60s, so I would be saving for an upgrade rather soon.
    12.5 at 115MPH.
    M6.
    NW Chitown
    2002 WS6
    12.04 @ 104 (missed 4th, but 1.7 60') or 12.xx @ 117 (bad 60', but good mph) on stock 10 bolt, stock TA, and M6 on 150 HP shot. Launched @ 2400RPM.
    My rear is definitely up for replacement early next year. Could have possibly been this summer but after spinning a rod bearing, that repair comes first.
    -Eagle
    | '02 WS6 M6 | KOOKS/ORY | LC-1 | LOU'S SS | UMI SFCs | BMN LCAs & RELOC's | Hotchkis STB | HSW 150 shot | Lid | 42# Lucas | HPTuner Pro |
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    Auto's will last a bit longer than M6's
    I still have my stocker.
    Forged 383 | ATI D-1SC
    NX MAF Kit | 222/226 .585 115
    AS Stage II 6.0L FI Heads
    Member krug07's Avatar
    skiatook oklahoma
    pewter
    01 trans am ws6
    eagle how did u spin a rod bearing?
    NW Chitown
    2002 WS6
    Tuning on this past Monday. Missed 1-2 shift spun the motor to 6300RPM and it began knocking.
    http://www.ls1.com/forums/showthread.php?t=87536
    -Eagle
  1. Fastest stock N/A?
    By TA98 in forum Drag Racing
    Last Post: 02-11-2012, 11:10 AM
  2. Question: Fastest stock time
    By 10spokess in forum Drag Racing
    Last Post: 02-21-2011, 05:27 PM
  3. Whats the fastest naturally aspirated 5.3 pass?
    By hotrod7575 in forum Drag Racing
    Last Post: 06-23-2010, 01:00 PM
  4. fastest stock shortblock ls2?
    By qwkgto in forum Drag Racing
    Last Post: 07-08-2008, 04:24 PM
