Results 1 to 14 of 14
    Member kiddynamite's Avatar
    Indiana
    2002 Trans Am WS-6
    Crazy Popping Sound When I Shift!
    I just got my car back from the shop...i had a set of heads, a cam, new pushrods, roller rockers and a timing chain installed and it drove 100% great earlier in the day, i just ran out to taco bell and on the way back every time i would try to shift a horrible popping sound would come from underneath the center console. it almost sounds like someone is on there and punching up every time i shift. 1st gear is the worst...what the hell is going on???
    Indiana
    2002 Trans Am WS-6
    hey, thanks for all the help...LS1.com is a great place to get good advice.
    Member 89LX's Avatar
    East Coast North Carolina
    Navy
    2000 Z28 M6
    Did you have a tune after the installs?
    Member DaddySS's Avatar
    Bergen Co. NJ
    2000 Camaro SS Conv.
    When you say you "would try to shift" you mean you got the noise while depressing the clutch, or shifting gears, or it sounds like exhaust backfire?
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Sounds like your exhaust came apart. Maybe something rattled loose. A large exhaust leak will make the entire car resonate, I've driven my car with open headers and its almost unbearable to be in the cabin.
    Check the exhaust for any obvious damage, if you find nothing bring it back to the shop that did the work.
    in my Trans Am
    2000 Trans Am WS6
    check your transmission mount,.....thats what it sounds like to me.
    Quote Originally Posted by TransAm11973 View Post
    +1... sounds like a broken trans mount...
    Junior Member Boat's Avatar
    Tracy, CA
    98 Z28 Vert
    +1...
    http://store.summitracing.com/partde...5&autoview=sku
    Houston, Texas
    2000 C5 Torch Red
    Out of curiousity, whats the best way to prove if it's the trans mount? Should you be able to see it rotting?
    NJ
    SGM
    1998 Trans Am WS6
    Go under the car and push up on the tailshaft. If the trans mount is broken, the transmission will lift completely off the crossmember. Thats how mine was when it broke, the stock mount split completely in half.
    Upgraded to a poly mount, its been good since.
    Quote Originally Posted by Wesman View Post
    i put a jack under my trans and jacked it up a little (1/2") and seenlight through the trans mount bushing...
    in my Trans Am
    2000 Trans Am WS6
    just a little extra note,....the mount does not have to be broken or even show major signs of damage to cause the trans tail to pop up.........these are stock rubber mounts that have a lot of play in them. even when we are talking about stock hp numbers...so you start adding etc and get more torque and hp and even more strain goes on that mount. Do NOT buy another stock mount. From what I have seen the newer rubber composition they used is even softer. Do yourself a favor and do this:
    Buy a Energy Suspension Transmission mount
    DO NOT USE THE PRE LOAD PLATE
    GRIND DOWN THE TWO PRELOAD "BUMPS" ON THE TOP OF THE MOUNT
    PUT THE MOUNT ON
    FORGET ABOUT IT AND DRIVE HOW YOU PLEASE
    in my Trans Am
    2000 Trans Am WS6
    P.S. when you grind the bumps down make sure they are flush with the mounting brackets on the mount. If you have any ??? just PM me.
    Springfield
    2004 SVT Cobra
    I used a giant belt sander to grind mine down. Worked great.
  1. Replies: 45
    Last Post: 07-21-2016, 08:12 AM
  2. Help: z28 camaro makes popping sound
    By dany3350 in forum General Help
    Last Post: 01-06-2013, 06:18 AM
  3. This might sound crazy...
    By Whiteboycntdnce in forum Drivetrain
    Last Post: 11-18-2007, 08:51 AM
  4. popping sound
    By CYCLONE GREY GTO in forum GTO
    Last Post: 10-04-2006, 02:53 AM
  5. 02 SS with popping sound
    By ajmad in forum Camaro / SS
    Last Post: 11-23-2005, 04:21 PM
