Results 1 to 11 of 11
Thread: No reverse lights?
05-22-2008, 09:46 PM #1
No reverse lights?
So I was replacing my right rear turn signal light on the tail lights last night and while I was at I decided to check the other ones. Anyways I noticed my reverse lights don't come on when put into reverse?? That's kinda scary to think i've been driving for who knows how long without them working. The bulbs aren't blown so what could it be? I'm guessing it's whatever is at the shifter that indicates to illuminate the reverse lights but I don't know where that is or anything else it could be so tell me what to look for. Thank you for reading.
05-22-2008, 09:52 PM #2
05-22-2008, 11:41 PM #3
05-23-2008, 07:10 AM #4
You have to get under the car, its kind of on the side of the transmission (Driver Side I believe) with a clip going into it. I took mine out and measured the resistance when the switch is pushed and it was out. its a real quick fix if you have access to a lift.
05-24-2008, 04:18 AM #5Senior Member
- Apr 2008
- Madison, WI
Auto or manual trans???
Was your ign key in th on position when you checked the rev lights?
05-24-2008, 12:22 PM #6
05-26-2008, 06:03 PM #7Senior Member
- Apr 2008
- Madison, WI
back up lamp switch on a 6 speed in on the passenger side about 5 inches rearward of the bellhousing
05-26-2008, 09:48 PM #8
05-27-2008, 08:48 AM #9Pony Killer
- Apr 2008
- Mississauga, Ontario, Canada
Black- 2002 Camaro SS M6
i used to have a 1995 firebird. i had the same problem. it was the reverse light switch. located on side of tranny but i forget whether it was driver or passenger side(i had a 5-speed v-6). real quick fix, made easier if you have the option to throw it up on a hoist. just pick up the new switch, and look for the identical one on your tranny
05-28-2008, 06:53 PM #10
05-30-2008, 10:40 AM #11
Question: 99 Camaro reverse lights dont work
By jamesthrash1 in forum General HelpReplies: 9Last Post: 05-08-2012, 11:10 AM -
By jamesthrash1 in forum External EngineReplies: 0Last Post: 05-04-2012, 11:35 AM -
Help: Moisture in reverse lights 2000 T/A
By fbodyNATION in forum Firebird / WS6Replies: 6Last Post: 09-20-2011, 12:07 AM -
Reverse Lights
By simzjr in forum General HelpReplies: 5Last Post: 12-13-2005, 11:25 AM -
Reverse Lights
By simzjr in forum General HelpReplies: 0Last Post: 12-12-2005, 10:31 AM
