Results 1 to 10 of 10
Thread: Blinker
    infantryman tingo99's Avatar
    Feb 2008
    MODESTO CALI.
    Blinker
    alright so today my blinker just stayed on everytime i turned the driver side on but my passenger side blinks fine just driver side stays on till i turn it off or turn i checked all the fuses dont know what it is
    Member Frozen WS6's Avatar
    EagleRiver, Alaska
    RED, BLACK
    2001 WS6, 1998 TA
    There may be a blown bulb in the front or back. If thats not it, there is the flasher on the fuse panel.
    Member Transam388's Avatar
    Cypress, TX
    98 Trans AM
    10 to 1 you just have a bulb that is bad. I have had it though where the bulb lit when the headlights were not on but went out when on. So you may just want to re seat if that is the case but normally it is just a bad bulb. At least you know which side to check!
    98 T/A: HPE 5.3 Heads, 238/242 113 cam, Kooks 1 7/8 stepped LT headers, Custom Y pipe, Cut out, Borla, NW 90MM TB, FAST 90MM Intake, TB Bypass, Under Drive Power steering and Crank, 150 Dry NOS, Yella Terra rockers, 3400 TC, HPE tuning,
    I agree. Check the bulbs, sockets, and flasher. More than likely just a bulb but these cars are notorious for rusting sockets.
    Feb 2008
    MODESTO CALI.
    cool ill check that right now thanks!
    Member 98 Stang Killer's Avatar
    Channelview, Tx.
    1998 Z28
    any body know the easy way to get to them i got big hands and arms its hard to squeeze my arm in there
    Feb 2006
    2002 WS6
    There should be trap door under the bumper cover below the signal lamp.
    Channelview, Tx.
    1998 Z28
    cool ill check it out real quick thanks
    Single Malt rbob93's Avatar
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    Quote Originally Posted by 98 Stang Killer View Post
    Pull the headlamp assembly.....takes less than 10 min. & you don't have to crawl under the car
    ls1ftw tigersport14's Avatar
    Tulsa
    98 trans am
    maybe your running low on blinker fluid...
  1. Question: blinker?
    By reaper ws6 in forum General Help
    Last Post: 04-01-2011, 09:44 PM
  2. GM Blinker
    By travs98ls1 in forum Almost Anything Goes
    Last Post: 05-13-2010, 05:50 PM
  3. Did the blinker mod
    By blindxeyed in forum Appearance Section
    Last Post: 01-25-2009, 05:31 PM
  4. help w/ front blinker
    By BluDetroit in forum Corvette
    Last Post: 09-20-2007, 01:10 PM
  5. Blinker problem
    By camarostripes96 in forum LT1
    Last Post: 09-19-2007, 05:57 PM
