Results 1 to 20 of 22
Thread: 4 Questions. ( Pics Inside)
05-22-2008, 06:06 PM #1
ok so just recently i got really anal about my car and decided that i need to fix everything and make it super nice and everything.
so i have some questions that hopefully you all can answer
1. My paint on my roof area is starting to flake. is there anything i can do about it?
2. OK so i started removing my side molding. when i bought the car the driver side molding was already removed for some reason ( it was in an accident they might have changed the door IDK ) but it looks like whats under the side molding dosent match the paint. can i fix this?
3. My tail lights dont match. hmmmmmmm does anyone have a spare that they wanna trade or can i fix it?
4. Is there any paint i can buy to fill in this area. Or does any one have any i can buy.
So Please help me. THX in advance
05-22-2008, 06:12 PM #2Member
- tx
pewter- 99 trans am ws6
you could probably get a small touch up paint can at autozone or the dealer. If I was you i would fix the door first and then worry about the paint problems.
my taillights are the same as yours. one of them is darker than the other
05-22-2008, 06:18 PM #3
hmmmmmmmmmmmmmmm wanna trade tail lights
05-22-2008, 06:42 PM #4
your tail lights should just be a lite that burned out, buff out the spot where your trim was
05-22-2008, 07:10 PM #5Grand Imperial Wizard
- Retired Outlaw Sum Bitch
Take it Jennings Anderson body shop...ask for Blainey...tell him Sarge sent you....
05-22-2008, 07:11 PM #6
05-22-2008, 07:21 PM #7
is this the one sarge
http://www.yellowbot.com/jennings-an...ntonio-tx.html
05-22-2008, 07:26 PM #8Grand Imperial Wizard
No...the body shop is on the other side of I10....got the big plastic Texan
05-22-2008, 07:38 PM #9
could you possible give me a sticky to the place
05-22-2008, 07:44 PM #10
#2 - It looks like the paint in the center is a perfect match. I'm guessing the outer area is left over adhesive. get some wd-40 or another product to clean up all the excess gunk from removing the side moldings. You should be able to clay bar/ wax it and it'll match perfectly.
#3 - does your driver tail light collect water? Mine originally collected water and the reverse tail lights looked like shit because of the condensation. I cleaned the inside out the best I could (rear light polished up nicely) and ran a bead of silicone around the whole light. After wards I drilled 4-5 holes randomly in the bottom of the driver tail light for venting. Tiny holes at the lowest point with a medium up higher. This removed all the condensation. Been a year and everything is holding up fantastic.
also, buy a 3dollar can of trim shine in the aerosol can and spray the black grill behind the driver wheels. all the discoloration will go away and leave a nice non greasy black.
Just my .02Last edited by chuckie669; 05-22-2008 at 07:46 PM.
05-22-2008, 07:49 PM #11
nope it dosent really gather water. im tempted to not even screw with it and take the car a whole different route and do Black CETA mod. Black out the tail lights and third brake light. but idk i think it would ruin it a lil.
05-22-2008, 07:49 PM #12
05-22-2008, 07:59 PM #13
Hmmmmm now that i think of it.... it might be condensation. how would i take off the tail lights?
05-22-2008, 08:40 PM #14Member
- tx
open the trunk and pull back on the cover and you will see about 5 plastic nuts. remove these and the light will come right off
05-23-2008, 07:29 PM #15
Kool ok Thx. And if there is condensation would I just wipe it or what should I do?
05-23-2008, 08:20 PM #16
might sound silly but I wiped up what I could and then took a shop vacuum with a small attachment that fits in the holes and cut out some scraps from cardboard (Cardboard Coke box). propped the light up against surface and cranked up the vacuum. Put the cardboard up against the other holes which created a vacuum. After a few min it was crystal clear until more moisture seeps in.
05-25-2008, 11:12 AM #17
For number 1, re-clearing is the right way to do it, but if you wet sand it it will make it look a little better.
05-25-2008, 11:53 AM #18Junior Member
- Apr 2008
- Orlando, FL
- 2000 Z28
Sand the clear where it is flaking and re-clear it, only real way to do it. For the other blemishes like the trim, it will probably be buffed out fairly easy. I was just at the autopart store and they have Duplicolor in just about every GM color in a spray can for touching up that one spot or any other spots. Make sure you get off ANY flaking paint off of the plastic/steel body panel before painting. If you lived in FL ide do it for ya, sorry.
05-26-2008, 09:27 AM #19
ok i know im asking some dumb questions but i took the tail lights off and couldn't figure out of to take off the light part. like i got the whole thing off but the part with the honey combs wouldnt come off. its probably really easy but im retarded
05-26-2008, 07:15 PM #20Senior Member
- Apr 2008
- Madison, WI
You basically need a new taillight. Water damages the "chrome" reflector inside the taillight and makes it looks darker. Check EBay, usually $225 new, possible a good used one for
$100.
To remove the red lens part from the taillight requires heat to soften up the glue. then you can gentlly pry it off. Be careful. too much heat can melt stuff, not enough heat and it won't pry off without cracking it. Heat gun works best
Anyone know anything about Jaguars? Pics inside...
By nitrox28 in forum Almost Anything GoesReplies: 18Last Post: 07-01-2010, 09:24 PM -
New appearance mod, pics inside
By KLRWS6 in forum Appearance SectionReplies: 21Last Post: 03-10-2008, 06:59 PM -
9's enabler! pics inside
By cam02ss in forum Almost Anything GoesReplies: 30Last Post: 02-07-2008, 12:54 PM -
HP Evos on WS6, pics inside...
By SLIKWS6 in forum Wheels and TiresReplies: 39Last Post: 09-19-2006, 02:06 PM -
02 Ws6 6 Speed FS/FT(PICS inside!)
By The95Z in forum Vehicles For Sale / TradeReplies: 4Last Post: 07-21-2006, 12:01 AM
