Results 1 to 20 of 27
    Oct 2003
    Charlotte, North Carolina, Uni
    2002 TT Camaro
    My Home made true dual exhaust on my 02 Camaro wit
    I made my own True Dual exhaust for my 403 cid APS twin car
    T 304 stainless 3 inch tubing Tigged up W/O mufflers but I will probaly add them later as it is still a little loud for my taste right now. The system comes out in 3 sections + the tail pipes split in 2 so I can drop the tranny pretty easy
    The longer than normal X pipe is 4 inch oval that fits aound the Spohn Torque arm mount that is straight and made for the stock or kooks exhaust. the car also has both front and rear Driveshaft safety loops which made it quite a bit harder to run the dual 3" tubing.
    (the green paint is where my 5 year helped me one night:bang
    doylestown, Pa
    SILVER
    2004 CTS-V
    GOOD JOB! Looks great! How long did it take you and be honest!??
    Oct 2003
    2002 TT Camaro
    a few weeks working on it a few hour each week + i was learning how to use the tig welder. I could do it again in 1 weekend
    doylestown, Pa
    SILVER
    2004 CTS-V
    Quote Originally Posted by Darren P View Post
    You learn pretty fast with the welder. I did custom TD's on mine too and it took many hours!
    Member cant.b.caught.z28's Avatar
    Feb 2008
    Wichita, KS
    2005 Ram Daytona
    that is very nice, i like it alot! I wish i knew how to tig weld, i want to make my own so bad.
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    Nice Darren! saw your post on tech.
    From now on out then, there isn't much reason for you to be buying anything but the turbo and manifolds
    Oct 2003
    2002 TT Camaro
    or just the turbos
    Boiling Springs SC
    2000 camaro ss
    hell yeah Darin well it was great talking to you, I am going to call you tommorow and talk more about the exhaust, ill see what we can work out, have a good day
    gabe
    Rice Killa JwMonE99's Avatar
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    Wow you have like my dream suspension. I am trying to get to that point.
    300RWHP, 341RWTQ
    1/8 mile 8.32 at 83.97
    1/4 mile 13.049 at 105.24
    doylestown, Pa
    SILVER
    2004 CTS-V
    I just noticed that you cut your subframe connectors! Are they welded in?
    Oct 2003
    2002 TT Camaro
    yes
    I cut it a few years ago for a single turbo kit that I used to have in the car.
    doylestown, Pa
    SILVER
    2004 CTS-V
    yes
    I am not sure if you are worried about it, or if you can even cut out the welds, but UMI's 3 point subframe connectors will clear your exhaust.
    Oct 2003
    2002 TT Camaro
    I just have to take the tube I cut out and weld it back in
    Albuqueruque, NM
    Very nice!
    Junior Member STL2SLO's Avatar
    Feb 2008
    Wisconsin
    1998 Camaro
    Looks very nice. I didn't think dual 3" would fit over a 9"?
    Oct 2003
    2002 TT Camaro
    Quote Originally Posted by STL2SLO View Post
    It is tight but I made it fit.
    1/8th Mile Killer 2KZ28's Avatar
    south carolina
    2000 Z28
    Were you racing at pageland dragway last weekend?
    Oct 2003
    2002 TT Camaro
    Quote Originally Posted by 2KZ28 View Post
    yes I was. I made 4 passes. last one I pulled the front tires just a little
    south carolina
    2000 Z28
    That car is wicked fast. hell of a sleeper. cant believe you actually drove it in and ran that fast. Im jealous! going back this friday?
    Stockitie Stock Stock 95camaroZNC's Avatar
    Raleigh NC
    1999 Trans Am
    That looks really good, can def tell youve done alot of suspension work on the car as well.
  1. true dual exhaust
    By 1999isada in forum External Engine
    Last Post: 01-18-2012, 06:05 PM
  2. Need True Dual Exhaust HELP!!!!
    By NewYawk WS6 in forum External Engine
    Last Post: 08-08-2008, 05:13 PM
  3. Video of my home made exhaust..
    By mvvette97 in forum External Engine
    Last Post: 08-15-2007, 11:14 PM
  4. True Dual Exhaust
    By GottaHaveLS1 in forum External Engine
    Last Post: 11-11-2005, 05:05 PM
