Results 1 to 10 of 10
    Ottawa
    Talking HID - projector/sealed beam solution?
    Hey guys,
    I have been throwing up and down the idea of pursuing HID headlights. From my research, I can see that the quick and easy route would be to replace the stock headlights with a sealed beam conversion kit (eurolamps.com) and then simply get an HID bulb/ballast kid (HIDKING on ebay) for a total cost of ~$200 and a few mins of your own time.
    Pros:
    - Moderate Install (worst case scenarios)
    - Low cost
    - Bright Lights and improved visibility
    Cons:
    - Illegal (in some states/provinces)
    - Blinding on-coming drivers
    - No-cut off
    The alternative, obviously is to pursue the projector retro-fit style HID's. This requires significantly more work but the end result is much more rewarding and professional looking.
    Pros:
    - Professional
    - Bright lights and improved visibility
    - True cut off
    Cons:
    - Significant work required
    - High Cost
    What about meeting in the middle with a projector sealed beam conversion headlight such as this: http://img.auctiva.com/imgdata/6/8/5...10313146_o.jpg
    Would this be a viable solution to be 'in the middle' of both worlds, having HID's and yet also having projector style headlights?
    Thoughts?
    Junior Member transambrotha's Avatar
    May 2008
    Fort Pierce
    98 Trans Am
    I would love to find a nice affordable option like those projectors, I wonder if they would fit right in our cars
    MADE MEMBER 2002 WS6 KILLS's Avatar
    Newport NJ
    2002 Jeep Wrangler Sahara
    Black 2002 Trans Am WS6
    C=('.'Q) wultdat's Avatar
    Cross Roads, TX
    Electron Blue
    2002 C5 Z06
    Quote Originally Posted by 2002 Ws6 Kills View Post
    Cross Roads, TX
    Electron Blue
    2002 C5 Z06
    I would just go with the Eurolamps & eBay HID kit. Also, you could always adjust the headlight so it won't blind people.
    Newport NJ
    I second that!
    Black 02 Trans Am WS6 M6 SLP Lid, Bassani Stainless Headers & Y-Pipe w/o Cats, Borla Exhaust, BMR-STB, LCAs & Reloc. Brackets, Panhard Bar, & SFCs, Eibach Pro-kit With Bilsteins, BF Goodrich G Force KDWs, Optima Yellow Top, 5% Tint, Blackouts, Clear Side Lights, H-7 Headlights much more to come!
    Senior Member predator's Avatar
    Little Rock, Arkansas
    1966 Corvette Coupe
    you have to be careful with HID... the reflector/projector needs to be made to handle it because the light isnt emitted from a point source as it is in conventional headlights... more of the bulb lights up and if the reflector isnt designed to handle that it will scatter light everywhere.
    -me
    Orlando, FL
    1998 Camaro Z28
    Yeah. No shit. Mine were really bad until I did the whistler mod
    Member cobrahunter's Avatar
    South Bay
    1998 Camaro Z28
    I've had mine on for just over a year. Have the lights pointed down just a bit, and never have had oncoming cars flash me with their lights.
    SOM WS6 fbird777's Avatar
    Kinston, NC
    Sunset Orange Metallic
    2002 Pontiac Trans Am WS6
    Yeah, before I adjusted my 8000k I had one guy flash his high beams 4 times before he got to my car, this was on my test run right after I installed them. After adjusting them I have only had about 3 people flash there high beams at me at night in about a month and a half.
  1. projector sealed beams
    By barryz in forum Appearance Section
    Last Post: 09-28-2010, 12:21 PM
  2. Sealed beam conversion
    By Goldcuffs in forum General Help
    Last Post: 11-30-2009, 08:47 PM
  3. Gonna do sealed beam conversion
    By patriot1136 in forum Firebird / WS6
    Last Post: 04-28-2009, 10:19 PM
  4. projector headlights
    By 1MileCrash in forum Camaro / SS
    Last Post: 07-05-2008, 02:37 PM
  5. sealed beam replacements
    Last Post: 05-30-2006, 06:43 PM
