Results 1 to 18 of 18
05-20-2008, 10:05 PM #1
Avg mileage you changed out your plugs and wire?
what is the avg mileage everyone swaps out their stockies and go with something else or just something new?
05-20-2008, 11:54 PM #2
- Mar 2006
- WI
- Blog Entries
- 1
Why would you want to change them? J/K
I'm going to do mine when I get to the headers next spring and do trans & motor mounts too. I'll yank the air pump and other crap all at the same time too. I hate taking things apart more often than needed.
05-21-2008, 01:25 PM #3
I changed the plugs around 75K 'cause I thought I should. Plugs looked great! Only reason I put in new ones is I had already purchased them!
No reason to change wires.
05-21-2008, 01:45 PM #4
- Apr 2007
- Newport, RI
Navy Blue Metallic- '00 Formy A4
I'm coming up on 77k and am going to change them within the next few weeks. Car seems to be running well, I got just hair over 24mpg my last tank, but it has a shake at idle, so I'm wondering if plugs will cure it.
05-21-2008, 02:05 PM #5
How do you get 24 mpg with an a4 I can't break 19!
05-21-2008, 02:06 PM #6
- Thornton, CO
I change the plugs once a year.
2500-3000 miles.
Wires are MSD. Should be good for quite some time.
05-21-2008, 02:16 PM #7
05-21-2008, 02:39 PM #8
- Jun 2006
- Ft. Lee, Virginia
Artic White- 2001 Chevy Camaro SS
I think he changes his plugs so often because they are not the stockers. Aftermarket plugs give you great performance, but have to be changed more often. The stock ones are made to last for a long time. I change my NGK's every 3,000 miles. Plus by no means is my valvetrain stock. But since I barely drive mine, that's about once a year for me. LOL!!!
05-21-2008, 02:40 PM #9
05-21-2008, 04:07 PM #10
I was driving 60 mi / day round trip on I 15 avg 70-75 MPH and got 20 mpg on a good day.
Moved to MO and drive 60 mi /day round trip, avg 55 mph and never get less than 22 mpg. Noticed an immediate increase in milage getting out of CA.
Out on the road, avg 70 mph, NOW, I get 25 - 26 mpg!
All this w/A4 AND 3.23 gears!
I do use cruise nearly all the time, even @ 55!
go figure.
PS: WFIW I love my new iMac!Last edited by A BAD T/A; 05-21-2008 at 04:08 PM. Reason: correction
A4 w/3.23s. 245-50x16 Kuhmo M550AS. MTI w/K&N & FRA, Hooker 'Cat-back', BMR LCAs. 1LE sway bar, urathane bushings, Bilstein HDs f&r. Granatelli SFCs, KVR cross-drilled front rotors with PBR "Metal Master" pads.
05-21-2008, 06:49 PM #11
- Apr 2007
- Newport, RI
All stock, 2,73's, and I drive like a grandma. Cruise set at 65, and I do mostly highway driving. I put on about 350 miles a week, work is 30 miles away from where I live, so I try to drive conservatively to cut my fuel bill down.
I get on it once in a while, but no racing and no holeshots.
05-21-2008, 09:10 PM #12
05-21-2008, 09:30 PM #13
I run mobil 1, I change my filter every 2,500 miles and top off the oil, every 5,000 I do a full oil change, every 10,000 I change the plugs. AP 103 plugs
05-21-2008, 09:37 PM #14
I did plug and wires at 95k, amazing huh, sparking still @ 95k lol but I now have MSD wires and E3 spark plugs
06-06-2008, 04:51 PM #15
tons of people run tr-55s and this is the first i've heard about someone needing to change them every 3k miles. most people put em on and leave em on forever w/o probs.
06-06-2008, 05:18 PM #16
- Sep 2005
- rochester,ny
pewter- 2001 z28 lingenfelter 383
06-07-2008, 04:13 AM #17
06-07-2008, 06:13 PM #18
- Dec 2002
- n/w chicago
mpg didnt improve at all with a plug and wire change.
a few bolt ons, 379 rwhp
11.96 @113.25
Changed my plugs
By Too Fast in forum External EngineReplies: 13Last Post: 03-12-2014, 04:14 PM -
Changed the plugs... whew...
By DrMilhouse in forum General HelpReplies: 4Last Post: 06-27-2009, 10:32 PM -
Changed the plugs, still skipping.
By Zapper2003 in forum LT1Replies: 26Last Post: 11-12-2008, 02:07 PM -
Changed plugs!!
By Huskerz1 in forum General HelpReplies: 18Last Post: 06-27-2006, 01:36 PM -
changed all fluids and plugs/wires - WOW
By snake_skinner00 in forum Camaro / SSReplies: 3Last Post: 03-22-2006, 09:51 AM
