Thread: New to the LS engines NEED INFO
05-20-2008, 05:52 PM #1Junior Member
- May 2008
- philly suburbs
Black- 1987 BUICK TURBO T
I am a buick V6 guy running a 9 sec turbo-t stage 2 motor and I want to go to a LQ4. I am tired of running C16. My combo for the V6 is a 244 ci stage 2 motor with a 3 bolt pt-88 turbo, front mount intercooler, and 83 lb injectors running FAST B2B fuel managment. I hear this a easy swap since I have a sumped tank and external fuel pump. I am also running a turbo 400 with brake and a 5500 stahl with a ford 9" 35 spline axles with 3.50 gear on 325 drag radials. Aluminum radiator etc... Tons of money in this car!! ANYWAY I want a solid 10.0 LS setup on pump gas and don't care if its a 5.3 or 6.0. I prefer to do the LQ4. I am trying to make the same 650 @ the wheels as the V6 did. Can I get someone to tell me what I should be looking for. What will the stock internals hold up to? Any info appreciated
05-21-2008, 04:57 PM #2
LQ9 6.0L starting with already 400hp
05-21-2008, 06:03 PM #3Junior Member
- May 2008
- philly suburbs
yeah but 10.1 CR isn't boost friendly. The 9.4 cr is still not where I wanna be. any one familair with pump gas turbo setups. Ie cam, heads, etc...
05-21-2008, 07:39 PM #4
Match things up well, turbo to ci I mean. I made 600rwhp at 10psi, but I run 16psi on the street with meth on pump for over 9K hard miles without issue. The f-quick link in my sig has setup in it.
05-21-2008, 07:41 PM #5Junior Member
- May 2008
- philly suburbs
thanks
LS2 And LS7 Engines - Gen Four
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 12-18-2009, 09:40 AM -
LS engines
By manyponies in forum Internal EngineReplies: 4Last Post: 10-12-2009, 08:15 PM -
New to LS Engines, have some ?'s
By RCcola55 in forum General HelpReplies: 6Last Post: 03-09-2009, 05:50 PM -
General info on LS1 engines
By 69Nova355 in forum General HelpReplies: 16Last Post: 03-03-2007, 05:23 AM -
Anyone have any info? (Computer info)
By blackSS01 in forum Almost Anything GoesReplies: 3Last Post: 02-01-2007, 01:44 PM
