Thread: Headlight module
08-14-2005, 10:36 PM #1Junior Member
- Texas
White- 99 Pontiac Formula
Headlight module
I have a 99 Formula
in which I believe the headlight module has gone bad
when I turn off my headlights the motor on the passenger side tends to run for about 6 or 8 secs after the light is already down
-I also have a ton of parts from my old 1995 Trans Am which I wrecked in the rain, I parted out the engine, trans, body panels etc...
(since the car only had 60k after 8 years)
but to get to my question
can the headlight module from my 95 be used in my 99?
same for the motors (actuators)?
and if I still wrong about the problem any other ideas?
I have tried looking up the part numbers but all I have found where prices at parts.com
I hope this was the correct place to post?
08-14-2005, 11:14 PM #2
Re: Headlight module
Yes it can be used on the drivers side. I used one from a 95 formula I got. You will have to cut the coonnections and splice them. Also the shaft on the headlight motor will be a little longer. So that being said you will have to bend the arm towards the stop when it goes closed. If I was you I would just go to www.projecttransam.com and go to the gear fix. I would just flip my gear. I wouldnt buy a new one.
08-14-2005, 11:26 PM #3Junior Member
- Texas
thats for the actuator correct?
did not check out the site yet
what about the control module?
99
http://www.trademotion.com/partlocat...15&catalogid=2
95
ThanksLast edited by kny3twalker; 08-14-2005 at 11:32 PM.
08-15-2005, 01:44 AM #4
Its not the module. Its a stripped gear. I have had the same problem.
08-16-2005, 04:56 PM #5Junior Member
- Texas
cool I plan to fix the motor or buy one from P&G, but I guess I am still interested to know if the module from the 95 will work in the 99?
headlight control module wiring diagram
By JROBINSON1016 in forum Stereo and ElectronicsReplies: 0Last Post: 09-28-2014, 10:58 AM -
For Sale: abs module,cruise module,water tem gauge
By sammy burks in forum Parts For Sale / TradeReplies: 5Last Post: 06-02-2008, 05:38 AM -
headlight module
By kris6273 in forum Parts Wanted / TradeReplies: 3Last Post: 09-11-2007, 01:03 PM -
headlight switch or control module?
By Zapper2003 in forum Firebird / WS6Replies: 0Last Post: 08-25-2007, 09:32 PM -
SLP IAT module?
By Ripper415 in forum External EngineReplies: 6Last Post: 10-30-2006, 10:12 AM
