Thread: plugs and cam
    Member blk_jaws's Avatar
    Eastern, Kentucky
    Black on Black
    2000 Trans Am M6
    plugs and cam
    When you do a cam swap do you have to remove the spark plugs?
    Colorado
    Mystic Teal/Chameleon grn
    1998 TA
    it's not required but since you're going to be taking everything apart you might as well. I think a lot of people go with NGK TR55's, and NGK TR6's if you go nitrous.
    Member silverz28camaro's Avatar
    Washington MO
    sebring silver
    2000 z28
    You do if you replace the valve springs. you will need to pressurize the cylinder when you remove the springs to prevent the valve from falling
    2000 auto camaro
    13.54 @ 104 2.049 60' stock 2.73
    12.94 @ 109 2.002 60' full exhaust, lid, tune, nitto 555r 2.73
    11.899 @ 114.44 1.686 60' full exhaust, lid, tune, nitto 245/50-16 555r 3.73 moser 12-bolt 2800 fuddle, ls6 intake manifold, slp under drive pully,fiberglass hood, bmr k-member
    Eastern, Kentucky
    Black on Black
    2000 Trans Am M6
    Quote Originally Posted by silverz28camaro View Post
    Thats what I wanted to know
    Thanks
    Eastern, Kentucky
    Black on Black
    2000 Trans Am M6
    I had another question.
    If I change the springs with the cam still in the car will still need to pressurize the cylinder?
    My Neighbors Hate Me!!! lvbroham1's Avatar
    Jun 2006
    Ft. Lee, Virginia
    Artic White
    2001 Chevy Camaro SS
    Quote Originally Posted by blk_jaws View Post
    Yes, the valves will still fall even if the cam is still in there. you still need to pressurize the cylinder to get the spring out.
    Washington MO
    sebring silver
    2000 z28
    Quote Originally Posted by lvbroham1 View Post
    Agree. the cam only opens the valves. The springs are what keeps the valve up. once you get the can torn down you will see exactly how everything works. go to www.ls1howto.com and read up a little on the cam swap. If you do not feel 100% confident on doing it yourself then either have someone experienced with this help out or a good shop. Its too much to risk if there is something not done right.
  1. E3 plugs
    By Black 98 formula ws6 in forum External Engine
    Last Post: 05-12-2010, 08:00 PM
  2. e3 plugs
    By kebie05 in forum External Engine
    Last Post: 05-14-2008, 01:17 AM
  3. Plugs and Wires Install...MSD wires E3 plugs
    By Demon_Z28 in forum External Engine
    Last Post: 05-04-2008, 03:53 AM
  4. New plugs w/ new NOS kit
    By Whiteboycntdnce in forum Nitrous
    Last Post: 06-11-2007, 04:51 AM
  5. spark plugs, tr55 iridium or plane tr55 plugs?
    By got-a-ls1 in forum General Help
    Last Post: 02-09-2006, 06:06 PM
