    Member ldanny's Avatar
    kemah,TX
    00 Formula M6
    those of you running electric cutouts
    where did you run the wires from the cutouts to inside the car? Also what wire did you splice into to get power when the key is on
    Arizona
    I ran mine up through the shifter boot so I didn't have to drill any holes in the car. From there its a simple ground and the other wire to 12 volt switched power.
    Stang Killer TransAmFanatic's Avatar
    Feb 2008
    Harvey, La
    1999 Trans Am
    i ran mine thru one of the drain plugs on the bottom of the car, and the switch i ran thru the firewall with my power wire for my sound system, i used zip ties to tighten up the wire and keep it from getting loose and dragging on the ground. i used the battery wire going form my starter to my battery for the wire, because it had a small wire with a but connector on it already.
    kemah,TX
    00 Formula M6
    so which wire did you splice into? b/c if you hook up to the 12V source off the batt. youll have power all the time
    Member Bouvers's Avatar
    Blue 1997 Trans Am(Sold)
    Pewter 2001 Trans Am Vert
    Quote Originally Posted by ldanny View Post
    well all I can say is when I hooked up my linelock they called for a ign. hot lead and you can find tonnes of them under the fuseboxes infront of the driver side fenderwell... I believe hot leads are red and ign. hot leads are pink...
    kemah,TX
    00 Formula M6
    Quote Originally Posted by Bouvs View Post
    thanks i just spliced into the fuse that controls the guages and it works perfect now.
    Laurel, Maryland
    2000 Grand Prix GTP
    2000 Trans Am WS6 M6
    Mine:
    Shifterboot and the Cig Lighter
    Cig Lighter is always live...
    I ran mine through the grommet under the passenger seat then used a quarter inch spade connector on the end of the wire and used an auxillary spot in the fuse box.
  1. Question: Electric Cutouts
    By Red 99 T/A in forum External Engine
    Last Post: 03-22-2009, 01:19 PM
  2. Electric Cutouts Yes Or No
    By 2fast2blegal in forum General Help
    Last Post: 08-12-2007, 11:26 PM
  3. Electric Cutouts
    By NiteRiderWs6 in forum External Engine
    Last Post: 01-14-2007, 02:52 PM
  4. NEW QTP dual electric cutouts!
    By BackinBlack02SS in forum Parts For Sale / Trade
    Last Post: 08-13-2006, 06:13 PM
  5. headers & electric cutouts
    By droppedblackws6 in forum External Engine
    Last Post: 10-28-2005, 11:51 AM
