Thread: simple driveshaft question
05-08-2008, 05:28 PM #1
i installed a DS safety loop about a month ago and had the foresight to mark and shaft and differential. only problem is when i went to install, the marks i made were rubbed off so i might have it flipped. my question is - if it is flipped, how much vibration will i get? i noticed a slight vibration today (i really dont drive the car much) when i drive 70+ mph and higher. at first i thought it was maybe a wheel became off balance, then i remembered the DS.
05-08-2008, 06:07 PM #2Slow'er'Ass
- Thornton, CO
You can't flip the driveshaft.
05-08-2008, 07:56 PM #3
oh sorry, not flip diff and trans sides but rather where its bolted to the pinion gear. im wondering if that slight vibration is from me having it rotated 180 degrees from where it was originally bolted.
05-08-2008, 08:30 PM #4
05-14-2008, 07:25 AM #5
My first guess would be tire rotation/wheel balance. A drivetrain/rear end shop should be able to balance your driveshaft for around $50-70, if you want the extra piece of mind.
simple header question
By 1WickedWS6 in forum External EngineReplies: 8Last Post: 12-30-2011, 02:42 PM -
simple suspension question
By RoadWrath04 in forum Suspension and HandlingReplies: 1Last Post: 11-02-2008, 07:37 AM -
a simple question
By zex Z in forum Camaro / SSReplies: 1Last Post: 07-24-2007, 08:52 PM -
Simple vs. question
By Formula_LS1 in forum Firebird / WS6Replies: 18Last Post: 10-31-2006, 09:48 AM -
Simple Sub Question
By MikeSomething in forum Stereo and ElectronicsReplies: 34Last Post: 10-06-2006, 05:11 PM
