Results 1 to 20 of 21
    Junior Member Footlead's Avatar
    Conroe Texas
    2002 SS
    Detonation,,,,Clatter at WOT
    2002 SS Camaro A4,,,,,, 40,000 miles I just bought the car and it is stock. I bought a SLP lid,,,,Donaldson Blackwing,,,and smooth bellows for it and put them all on,,,,,,Fit was great. Now under WOT,,, full acceleration it detonates and clatters with 93 octane. It did not clatter before install. I have put 2 different brands of 93 octane fuel and the same thing. Anybody know what the deal is??? Bad gas or did the simple mods change it??
    Thanks
    Bragg NC
    Met. Sunset Orange
    01 SS
    Any codes? Did you damage your maf while instailing? Check all of your connections, Maf and Iat sensor.. Make sure your maf is facing the right direction.
    J
    MADE MEMBER 2002 WS6 KILLS's Avatar
    Newport NJ
    2002 Jeep Wrangler Sahara
    Black 2002 Trans Am WS6
    ????Strange????
    Jun 2006
    USA
    2001 WS6, 2003 SRT4(sold)
    Very strange indeed. I have something a tad similar going on, though I can't seem to reproduce it. Sometimes, whenever I am WOT and in high RPMs, I'll hear clicking/clatter... 93 Octane, Shell V-Power gas, and I've seafoamed the car. Twice. I also flushed the coolant system. Hmm.
    mods: SLP Lid, Ported & Polished TB, 3.5" Magnaflow cat-back, SFCs. 42k miles.
    Conroe Texas
    2002 SS
    The MAF is facing the right direction etc.etc. Runs just fine except under WOT in gear. Everything looks fine.
    Jun 2006
    USA
    Change your spark plugs & wires. If that doesn't help fix it, get it tuned.
    old timer blue02Z's Avatar
    2002 Z28
    ^^^^ my thoughts exactly
    Conroe Texas
    2002 SS
    Thanks for the help!!!
    I have a Diablo Predator programmer coming and I will change the plugs and maybe the wires. The car only has 48,000 miles on it.
    Aug 2000
    Indy
    sure the maf isn't damaged all connectors tight ?
    Senior Member Blown Interceptor's Avatar
    Jul 2000
    San Diego, Ca
    1999 Camaro SS
    Quote Originally Posted by Danger731 View Post
    Like you know what you're talking about?
    Retired Outlaw Sum Bitch
    I would go one heat range cooler with my plugs. Example...if your running NGKTR55's go NGK6...
    Conroe Texas
    2002 SS
    Maf
    The MAF looks fine and all connectors are tight
    Do you think maybe your getting more air flow over the MAF and now it has adjusted the A/F? I mean isnt that the purpose of the mods you listed? Go one notch cooler on your plugs...if the MAF doesnt relearn and it goes away.....
    Conroe Texas
    2002 SS
    Who Knows
    Correct..... You would think that It would have more air flow and maybe it leaned out some but the computer etc.etc. should have noticed that and compensated for it. I may have gotten some 87 octane for 93 octane prices if you know what I mean. The MAF and computer should adjust for this I would think,,,,,,, It is not like the SLP lid,,,Blackwing filter..and smooth bellllows would make night and day differences,,,but maybe they do.
    Jul 2000
    San Diego, Ca
    1999 Camaro SS
    I am assuming you took the negative battery cable off for a few minutes to let the PCM relearn?
    Yeah I was just trying to get folks to 'think"
    That MAF isnt adjusting to the newfound air.....reset that MAF man....
    Conroe Texas
    2002 SS
    Maf
    I did not disconnect the battery. I assumed that it would adjust the mixture,,,,,did not know the power needed to be shut off. I will do that today.
    Thanx
    Two fuse panels on the drivers side in the front. With the ignition on pull the two PCM fuses (one in each fuse box). Wait for 3 min., then shut off the ignition and replace the fuses. Start car! It will idle like crap for about 5 min until the computer relearns it's air to fuel ratio's.
    Aug 2000
    Indy
    Quote Originally Posted by Blown Interceptor View Post
    I'm gunna come over there and take your lunch money.
    Conroe Texas
    2002 SS
    Fixxxxxxxxxxxxxxxxxed
    Did what Sarge said and it Fixed the problem.
    Thanks
  1. Help: Detonation in the Rain
    By herculesrider1 in forum General Help
    Last Post: 07-09-2013, 02:52 PM
  2. Low RPM Valvetrain Clatter
    By MarcZ in forum Internal Engine
    Last Post: 04-24-2013, 08:04 AM
  3. Help: detonation, tried everything
    By 02fbody35th in forum General Help
    Last Post: 08-01-2009, 01:09 PM
  4. !!!!!!!!detonation!!!!!!
    By silverz28camaro in forum Computer & Tuning
    Last Post: 05-30-2008, 10:13 PM
  5. detonation at WOT
    By sic2001 in forum General Help
    Last Post: 03-08-2008, 12:08 PM
