Thread: please help strut noise
05-07-2008, 06:33 AM #1Junior Member
- Apr 2008
- cincinnati
mystic- 2000 trans am
ok so just installed my pro kit and one strut had the classic rust bla blah. so replaced it with new and wasnt sure if i needed the gold metal peice from the stock strut it was not coming off the old strut so switched all the ruber peices and put on the new one now it makes a rattling sound when it hits a bump like somethings loose. also the back is squeaking very bad anyone ran into this before. any help
thanks
05-13-2008, 01:53 PM #2Member
- Sep 2006
- OKC
Artic White- 2002 ws6
I am having the EXACT same problem. Last summer I installed the Hotchkis spring kit and ever since i've been having that problem. Two different shops couldn't hunt it down. Now it's gotten to the point that when I turn my wheel as sharp as I can and get it rolling... I hear a similar clanking sound. You might try that and see if you hear it then too. I'm dropping it off at another place in the morning. Let me know if you find anything out and I'll do the same. Good Luck!!!
09-08-2012, 08:55 AM #3
I am having the same issue as well, I replaced the strut mounts, struts, springs, and perches and I getting a clanking noise when I hit bumps too. Anyone found a fix?
09-08-2012, 04:00 PM #4
Im wondering if springs are sitting in the seat properly?
11-04-2012, 04:06 PM #5
i found my problem, probably after months of unsafe driving. Turns out it was my strut mounts, they were completely blown out, the metal sleeve and the rubber around it had ripped out from the rest of the mount. It was really hard to see on the car, so hard even Speed Inc in schaumburg missed it and accused my rack and pinion as the cause of the violent bumps and rattles. My car is lowered so that is why it was hard to see even on a lift, but one of the local brake shops pointed it out and a f-body speed shop could not. After i pulled them and replaced them no more rattles and rock solid. I would check that out.
11-04-2012, 04:31 PM #6
I believe I have the same problem, I was going to go hunting for it soon, I will start with this. Thanks for posting.
- - - Updated - - -
Where did you get the replacment?
11-04-2012, 05:45 PM #7
i first bought KYB strut mounts from summit. The replacements i purchased from carquest. If you jack up the car and can slide your finger between the spring to touch the bottom of the strut mount and you feel sticky rubber then its probably shot. If you take some time to pull the bottom bolts off the strut the shock with just fall out cause its not being held into the strut mount.
11-04-2012, 06:21 PM #8
I will def check that out. I just recently replaced struts, ball joints, bushings, the list goes on, but not those mounts.
Do i need a new strut
By cancam99ss in forum Suspension and HandlingReplies: 7Last Post: 08-17-2010, 07:54 PM -
My new KYB strut makes a creaky noise in rain only
By BlackZ28629 in forum Suspension and HandlingReplies: 3Last Post: 11-11-2006, 07:21 AM -
What way does the strut go??
By CitationZ06 in forum Suspension and HandlingReplies: 4Last Post: 09-17-2006, 09:46 AM -
Strut Bar
By camarostripes96 in forum Parts Wanted / TradeReplies: 0Last Post: 08-17-2006, 03:38 PM
