Thread: A quick question
05-06-2008, 06:43 PM #1
A quick question
On what temperature do you guys have set for your fans to come on iam using the diablo its for a GTO
05-06-2008, 07:21 PM #2
i have mine coming on at 170*
05-07-2008, 05:18 AM #3
I found it best to scan while driving and find the crack open point for the thermostat,,,then set the fans a little higher.
On mine, I found my 160 stat doesn't start to open until 172-173 degrees (go figure) and the engine would settle around 175-176 degrees while cruising. So to keep my fans from running continuously,,,and cycle as they should,,,I set my fan temps a little higher.
I have them coming on at 183 and off at 180 degrees for the primary fan,,,and on 185,,off at 180 degrees for the secondary fan.
05-07-2008, 06:50 AM #4Senior Member
- Jul 2005
- Jacksonville, FL
With a 160 I have mine set at:
Fan 1 On 184/off 175
Fan 2 On 194/off 185
05-07-2008, 10:01 PM #5
the key here is that if you haven't put in a cooler stat leave the fan settings stock.
Quick Question
By kenro23 in forum General HelpReplies: 14Last Post: 04-20-2012, 07:47 PM -
Quick Sig Question
By tatertot91 in forum Almost Anything GoesReplies: 12Last Post: 09-23-2009, 10:34 AM -
another quick question.!
By silverWS6 in forum Firebird / WS6Replies: 3Last Post: 07-11-2009, 05:37 PM -
Quick question
By hardcore_ls1 in forum Firebird / WS6Replies: 1Last Post: 04-17-2009, 03:25 PM -
Quick Question About SLP Air Lid
By aerojt in forum External EngineReplies: 8Last Post: 08-13-2007, 07:07 PM
