Results 1 to 13 of 13
Thread: Code P1416
    Midwest
    Code P1416
    The service engine soon light came on last week. Took it to Autozone to scan. The code showing P1416 - Secondary Air Injection (AIR) System Bank 2 . Can anyone tell me what to look at first ?
    Thanks for the help.
    Senior Member
    Jacksonville, FL
    Most likely cause is a clogged passenger side air check valve.
    Midwest
    thank you
    Is that easy to replace ?
    Senior Member
    Jacksonville, FL
    Yes, pick one up at the parts store and do it yourself. It screws into the metal pipe coming off the header, then connects to the hose with a clamp.
    Midwest
    Thank you !
    Ordered the part yesterday and it should be in tomorrow.
    Member Joe00SS's Avatar
    CT
    White Liquid Silver
    2000 Camaro SS/ 02 YZF-R1
    Did that fix it? Mine just threw the same code and Autozone scanned it.
    Midwest
    the parts are not in yet, but strange, the SES light went away, don't know if it's becasue the weather is 30 degrees cooler than the past few days. I am still planning to replace the check valves.
    CT
    White Liquid Silver
    I took mine apart and cleaned the check valve and air pump with seafoam spray last night and this morning no more light...I drove it all day and so far so good!
    Midwest
    Finally had time to change the check valves, the driver side didn't look too bad, the pass side was almost completely clogged. It had chunks of black stuff all over the inside. Probably could have only replaced the pass side, but I replaced both.
    CT
    White Liquid Silver
    Did the light go off and stay off? Mine has come back on.
    Midwest
    SES light has NOT come back on since the change.
    CT
    White Liquid Silver
    I just cleaned the driver side one which was pretty bad....and no light again for a few days, I'm going to order new ones and just get it over with.
    Princeton, IN
    I think the computer can tell if the air injection is working by the o2 sensor. The o2 sensor will show the exhaust go lean when the pcm commands the pump to run so you might want to check your o2 sensors. You might have to find someone local with a scan tool to do this.
    Also make sure you don’t have any holes in the tube coming from the air pump. There should be one main line and then a y at some point.
  1. Help: OBD Code P1416
    By king245249@bellsouth in forum Computer & Tuning
    Last Post: 10-07-2009, 09:01 AM
  2. DTC Code P1416
    By 2KN1Z28 in forum General Help
    Last Post: 05-04-2007, 06:28 AM
  3. Code P1416
    By paxton62 in forum Computer & Tuning
    Last Post: 11-03-2006, 08:06 AM
  4. SES Code P1416
    By KM02SS in forum General Help
    Last Post: 10-04-2006, 03:31 PM
  5. code p1416 help please!
    By BlinkFan0072 in forum General Help
    Last Post: 04-23-2006, 05:50 PM
