Thread: clutch setup?
    san diego
    98 ta
    clutch setup?
    what kind of setup should i do for my t/a. i just put a exedy twin plate clutch in and to get the car into first and reverse when im sitting still i have to push to clutch all the way to the floor and its still a pain in the ass to get it in gear. the clutches pressure point is like right when i let off of it instead of maybe half way out like i think it should be. what can i do to fix this? its already bled all the way so i know thats not the problem, and i just put a new master slave in it so i konw thats not it eather.
    Senior Member Tobynine9's Avatar
    Cypress, Texas
    Burple
    1966 427 Cobra Replica
    adjustable master cylinder?
    san diego
    98 ta
    nope i sure dont have an adjustable master slave.
    Member tici's Avatar
    Zurich - Switzerland
    1998 M6 vert TA
    Quote Originally Posted by 98silveraptorhoodws7
    Tobynine9 means you'll probably need one...
    I'm the same opinion.
    Cypress, Texas
    Burple
    Say that again, brother.
    My clutch is fine. I was suggesting an adjustable unit for his new Exedy clutch. The adjustable master cylinders allow you to adjust where the clutch engages/disengages. That might fix it. But it's another $300 on top of your super-essspensive Exedy.
    1998 M6 vert TA
    ...or modify the stock unit.
    I did it and it works like a charm.
    The McLoud adjustable master has a bigger diameter: it moves more fluid with the same piston movement.
    You can also play with shims under the slave cylinder but it's a pain in the butt.
    MODS: A4 > M6 conversion, SC raptor hood, Vortech V9 G-Trim SQ, homemade water-alcohol injection
    DYNO: 410 RWHP, 417 TORQUE @ 5 PSI
  1. New Tic Master Cyl with current LS7 Clutch setup?
    By NCal in forum Manual Transmission
    Last Post: 05-09-2012, 07:04 AM
  2. Which clutch setup?
    By dbs1 in forum Manual Transmission
    Last Post: 01-22-2010, 08:01 PM
  3. Question: clutch needed for special setup
    By bhsshop in forum Manual Transmission
    Last Post: 01-20-2010, 02:26 PM
  4. Replies: 21
    Last Post: 12-13-2007, 07:41 PM
  5. WTT: My 4L60E setup for your T56 setup!
    By 4birdman in forum Parts For Sale / Trade
    Last Post: 03-16-2007, 12:26 PM
