Results 1 to 14 of 14
    Member TedsB4Csled's Avatar
    Feb 2008
    Asheville, NC
    2002 B4C
    Yet more tune HELP needed!!!
    So I was also not wanting to go the mail order tune route, although I almost did. I found 409motorsports in Sc who said they would do a tune at a show and then dyno it. Not really a dyno tune but, a little better than just a tune. Shaw, an attractive female tuner(woohooo sucked in already), did the tune. She claims to have owned, tuned and modded LS1s. She used LS1 Edit. Changed gears to 373, set fans for 160 therm, changed the shift points & firmness, basic tune and deleted codes...etc...for $100. Here's my first question: Why does the "Service Engine Soon" light not come on when key is in "on" position and car has not been started? Is it supposed to be totally disabled? The emission codes being deleted is fine, but what if something else happens? I won't know about anything being wrong. Second: The car runs better, but my Dyno was horrid! Granted there was problems with the tech using my hand controls(watch dyno fire video/explained here: http://www.ls1.com/forums/showthread...65#post1453465) I will post my Dyno soon as I can....it is NOT smooth. I was going to run the car on the dyno myself as I know the hand controls best and Shaw would evaluate again, but it started to rain. She told me we could do it another time, I hope she stands by her words. The Dyno runs were only $50 and they gave me half back, and they did more runs than they could have. Could I have an issue with exhaust, other mods or even TPS? Or could it be the tune. They assured me it was ok, but I am very apprehensive. Last: Shift points were all set at 6000 rpm when she went on PCM, but it don't happen...she was stumped on that one which makes me think TPS? I am considering another tuner who has great revues with dyno tune, but that won't be for a while or maybe I should bite the bullit and do it soon? The car runs poorly on take off IMO, but highway and mid-range are good enough for me. So close, yet so far .
    Thanks for all the help and listening to my newby rants/concerns.
    Feb 2008
    Asheville, NC
    2002 B4C
    ...me again...my temp reading doesn't seem that much different with 160 compared to stock on there, just a little difference. Is that normal?
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    Quote Originally Posted by TedsB4Csled View Post
    temp gauge is a "fake" reading. only the 98 gauges actually worked.
    Feb 2008
    Asheville, NC
    2002 B4C
    Feb 2008
    Asheville, NC
    2002 B4C
    I will post NEW dyno soon...scroll down...
    Nick Williams!!! He tuned my car today, CORRECTLY! 315rwhp - 325+rwtq AND it shifts right, runs right and did not catch on fire!
    GO TO NICK WILLIAMS IF YOU NEED A TUNE. Mooresville, NC 2hrs from me, but hell if that was worth the overpriced gas and they charged me $300 for complete dyno tune!!!! My luck, or car luck has changed!
    NW Chitown
    2002 WS6
    My car used to warm up and run the temp to about 208*. Then I installed a 160* stat and dropped the fans to kick in above 180* and kick off @ 175*. According to HPT, the car will now sit at a idle and run @ 176*. Looking at the dash, the needle sits in EXACTLY the same place.
    Understand that the gauge is pretty much there for dummy light purposes. Its only useful @ the extremes to let u know if things are definitely whack.
    -Eagle
    NW Chitown
    2002 WS6
    Amazing what happens when you get an actual tune from someone that knows what they're doing versus someone who just has an idea and a nice set of legs
    LOL
    -Eagle
    Feb 2008
    Asheville, NC
    2002 B4C
    oh it was 314.9(315)hp and 332rwtq!!!!!! How do I post it? Oh i need URL....hmmmmm.let me think....
    12.36@109 Red on Red WS6's Avatar
    Tulsa OK
    1996 Trans Am
    Fake readings??? Why would a 98 be any different than 96 to 2002? Every LT1 and LS1 I have checked have been within a couple degrees from computer to dash readings.
    Good numbers.
    Make a photobucket account and upload them and copy and paste the link provided by photobucket.
    Feb 2008
    Asheville, NC
    2002 B4C
    I was scolded on here so much about the Slowmaster, i took it off. Going to dyno it again. SOP is even better without it! I'll decide wether to keep it or not after the results. Thanks!
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    Quote Originally Posted by Red on Red WS6 View Post
    Nah, there is a bulletin about in in 98... in 98 people saw the normal swing of the cooling syetem and kept taking their cars in for service saying it was wrong for the temp to swing so GM dummied out the guage in the 99-up cars. They have a warming up area, up to temp area and an overheat area.
    NW Chitown
    2002 WS6
    Warmed up and at idle my gauge sits about 1/8" to the left of center (212*) yet my laptop reads 176*...
    -Eagle
    Feb 2008
    Asheville, NC
    2002 B4C
    Nice.
    Tulsa OK
    1996 Trans Am
    Thanks, Good info to know. I have never seen it personally, but I have a guy coming over this weekend with a 00 SS I will look a little closer at it.
  1. Question: mail order tune needed
    By blackz28m6 in forum Computer & Tuning
    Last Post: 08-10-2014, 04:35 AM
  2. Question: Tune needed?
    By RileyC in forum External Engine
    Last Post: 04-13-2010, 10:00 AM
  3. Is a tune needed?
    By ctip'sTA in forum General Help
    Last Post: 04-17-2009, 07:18 AM
  4. South Carolina tune needed!
    By Hot Rod SS in forum Eastern Members
    Last Post: 07-23-2007, 11:38 PM
  5. Orlando Tune Needed
    By Robert_Ayala in forum Computer & Tuning
    Last Post: 05-07-2007, 08:03 AM
