Results 1 to 13 of 13
    Carmel, IN
    1995 Camaro Z28
    Cammed 2000 Trans Am
    2000 Pontiac Trans Am
    Color: Pewter
    Miles: 86,5xx
    Transmission: 6-speed
    T-tops
    I bought this car in November of 2007. When I bought it, the car was completely stock with 79K miles. The transmission had a bad 3rd gear synchro and I went ahead and had the transmission replaced. This car is in perfect running condition, there are a couple of scratches on the hood, and some of the chrome on the inside of the wheels is beginning to flake.
    All the cam, valvetrain, and suspension mods were put on within the last 2000 miles, the RPM Transmission has around 3000 miles on it.
    Modifications:
    Comp Cams 921 Spring Kit
    Comp Cams Hi-Tech Pushrods
    GM LS6 Oil Pump
    LG Motorsports G5X3 Cam
    LS2 Timing Chain
    SLP U/D Pulley
    Hooker Cat-back
    Stainless Steel Long Tube Headers
    Stainless Steel Y-pipe
    Speed Inc Stage 8 Locking Header Bolts
    LS6 Clutch
    Pro 5.0 Short Shifter
    RPM Level IV Transmission (media blasted transmission case, solid synchronizer keys, steel 3-4 shifter fork, handfit sliders and hubs, compressed carbon blocking rings, bronze shifter bushings, bronze fork pads)
    Eibach Pro-Kit Front Springs
    Stock Rear Springs w/ Heater Hose Mod
    Energy Suspension Poly-Urothane Sway Bar Endlinks
    KYB GR-2 Shocks
    Ported and Polished TB
    Ported Thunder Racing MAF Ends
    SLP Air Lid
    SLP Smooth Bellow
    K&N Air Filter
    AEM Uego Wideband
    MBA Phoenix Shift Knob
    Raptor Shiftlight
    New Upgraded Clutch Master Cylinder
    Drill Mod
    Free Ram Air Mod
    !AIR
    !EGR
    !CAGS
    !CATS
    I also have a 160* Thermostat that has not been installed. To install it, you'd need a new thermostat housing which is $29 on gmpartsdirect.com.
    Also parts that will come with the car is the stock cam, valve springs and retainers, pushrods, crank pulley, front springs, rear shocks, rear spring isolators, stock exhaust manifolds, t-top shades, and I'm sure there may be a couple other parts around here.
    This car should be making around 390RWHP through the LS1 intake manifold, a quick LS6 swap would put you over 400RWHP. The tune on the car is fairly conservative and runs 12.9:1 AFR. If you wanted, I'm sure you could squeeze a few more HP with a more aggressive tune.
    The Bad:
    -The clutch pedal still sits on the floor at WOT and high RPM's, the car still drives perfectly fine under normal driving. We replaced the clutch master cylinder and did the drill mod in hopes to fix this, a 2001 or newer clutch slave cylinder should take care of this. I do have one sitting in the garage but have not had the time to swap it out. For an extra $100 I could through it in with the car as well.
    -The driverside header collector taps the floor pan on first start up, but ones the car warms up or runs for a bit the tapping does go away.
    Idle clip right after cam install:
    I have a clean and clear title IN HAND as well as most of the receipts for parts I have put on the car.
    Price: $11,000 OBO
    If you have any questions or want more info/pics PM me or email me at black_95_z28@hotmail
    The only reason I am selling the car is to save up for a 97+ vette. I have wanted one for a LONG time now, with all the other cars I've had and the money I put into them I could have easily had one by now, but I am determined to have one as my next car. I would prefer NOT to sell this car sight unseen.
    Parma Heights, Ohio
    2 (100%)
    SOM
    99 Trans Am
    Hmm if my car sells, i may have to come take a look at this one. Was the front bumper repainted?
    Carmel, IN
    1995 Camaro Z28
    Quote Originally Posted by Ryans99LS1 View Post
    Yes it was. The owner of the dealership I bought it from said it had a lot of rock chips in the front bumper when they received it so they repainted it. They didn't do the best job matching it to the rest of the body, but its not too bad in person.
    Parma Heights, Ohio
    2 (100%)
    SOM
    99 Trans Am
    Yeah had a bumper repainted on my car and pictures bring out the worst of it. In person its almost unoticable. Ill be in touch if my cars sells though..
    Carmel, IN
    1995 Camaro Z28
    sounds good, just let me know.
    Carmel, IN
    1995 Camaro Z28
    bump, price adjusted!
    The Devil You Know!! TooFastT/A's Avatar
    Colorado
    2 (100%)
    1998 Trans Am WS7
    So I see that you decided against getting a Vette! Your thread over at LS1Tech is more recently updated, and it says your looking for a DD.
    Anyways, If I could convince the wifey to trade her 97 Corolla and you would want it, I would sooooo be all over this!
    Good luck on this sale man...your gonna make some lucky ass person very happy!
    1998 WS7 T/A M6| SLP:Lid,Line Lock,LM Exhaust w/ORY,Skip Shift| Pacesetter LT| 80mm BBK TB| Centerforce LS6 Clutch| Eaton Detroit TrueTrac Differential| MAC Diff.Carrier Girdle| 3:73 Gears| Spohn Cntrl Arms| Hotchkis Adj PHB| H&R Lowering Sp.Springs| NX 150 Shot Direct Port|More Mods... FQuick Page
    Carmel, IN
    1995 Camaro Z28
    Quote Originally Posted by TooFastT/A View Post
    I would love to still get a Vette! Either way, once this car sells, I'll be getting a new DD too, so I figured why not to "sell" it and get a DD at the same time.
    Colorado
    2 (100%)
    1998 Trans Am WS7
    Quote Originally Posted by black_95_z28 View Post
    I hear ya on the Vette! I've been wanting one ever since I could remember, but years ago when I worked at a Chevy Dealership, I got to transport a '99 Vette about 80 miles to another dealership....I fell in love!! I bout creamed my pants when I buried the needle on open stretch of Highway!
    BTW, any interest in a 1997 Toyota Corolla? Perfect on gas considering it's a 4 banger...plus it is pretty nice!
    Carmel, IN
    1995 Camaro Z28
    Your Corolla plus $7-8k and I'd say we could work something out.
    Lafayette, IN
    hey man i'm very interested... shot you an email
    i'd love to take a look at it sometime this weekend if you've got the time, i'm over in the avon/brownsburg area. let me know if that's too soon!
    Carmel, IN
    1995 Camaro Z28
    Sent you an email back, I get off work at 7pm on Saturday, but I have all day Sunday off.
    Carmel, IN
    1995 Camaro Z28
    bump for today
  1. For Sale: Cammed 2000 Z28 A4, new LS1! - $7500
    By Longshot in forum Vehicles For Sale / Trade
    Last Post: 06-21-2010, 01:12 PM
  2. Cammed 2000 Z28
    By Cookie in forum Vehicles For Sale / Trade
    Last Post: 10-28-2009, 07:52 AM
  3. cammed 2000 z28
    By smax in forum Vehicles For Sale / Trade
    Last Post: 03-28-2007, 08:47 AM
  4. 2000 cammed camaro ss fs
    By fast00ls1 in forum Vehicles For Sale / Trade
    Last Post: 04-11-2006, 08:29 AM
  5. 2000 cammed camaro ss fs
    Last Post: 03-27-2006, 07:04 PM
