Thread: Rear end rebuild
05-02-2008, 12:49 PM #1Junior Member
- Apr 2008
- Ft Worth
Green- 94 TA GT
Rear end rebuild
Had to replace pinion bearings today due to noise from the rear of my WS6 TA with 75K miles on it. When it was torn apart and the axles removed, the axles were found to be scored from the wheel bearings.
Ended up having to replace both axles, both wheel bearings, pinion bearings, and carrier bearings.
I guess I know where my gov't tax rebate check is going.
05-02-2008, 06:30 PM #2
05-03-2008, 05:48 AM #3Junior Member
- Apr 2008
- Ft Worth
Green- 94 TA GT
Here are photos of the damage at the axles....
05-03-2008, 05:50 AM #4
its not worth the money to rebuild that
05-03-2008, 07:27 AM #5Junior Member
- Apr 2008
- Ft Worth
Green- 94 TA GT
Total cost, including new rear axles and labor was $1,200. Each axle was $250 each. I dunno if it was the right thing to do or not, but I am trying to keep the car stock. Time will tell...
05-03-2008, 09:15 AM #6
dude you could of found a used 12 bolt or 9" for 1,700-1,900 or buy a new one for 2,200 and never have to worry about this happenning again.
05-04-2008, 05:57 AM #7Junior Member
- Apr 2008
- Ft Worth
Green- 94 TA GT
I don't have plans to ever take this car to strip or race it, so I am happy with the 10 bolt if it will just stand up to daily driving and not make noise.
I am now noticing noise in coast and decell after the rebuild, so I guess they didn't get the backlash set right, so it is going back.
If I had a lift and lots of spare money, I probably would just install a whole new rear end, but I guess I just thought I could get it repaired. I'm new to this car and still learning it's weaknesses. My 94 TA never had a single problem with the stock rear end, and was quiet through it's whole life (after putting in some additive for the limited slip).Last edited by Fred H.; 05-04-2008 at 07:32 AM.
05-07-2008, 10:53 PM #8Impounded
- Oct 2007
- Beaver Dam KY
I thought about rebuilding mine but if I ever want to drop in something other than a stock ls1 im doomed to get a 12 bolt. Where do they sell good bolt in replacements??
05-09-2008, 07:49 AM #9
I just replaced the rearend in mine.Got a low mileage 4 channel 3:23 for $250
rear end rebuild
By jezzell88 in forum General HelpReplies: 25Last Post: 02-17-2012, 06:41 PM -
Help: Rear end rebuild
By 01NavyBlueSLPSS in forum Western MembersReplies: 0Last Post: 07-03-2011, 05:10 PM -
Rear end rebuild
By JayTA98 in forum DrivetrainReplies: 15Last Post: 11-26-2010, 05:35 AM
