    Member Hot SS's Avatar
    IL
    15" drag rims on my camaro
    hi i have a 2001 camaro ss. and im getting 15"x10 drag rims for it. i want to know what would be the right backspacing? i also want to kno if this 15'' would fit with no problems with the 275 65 15 tires. thx
    29" tall tire??
    Good luck fitting that.
    The backspacing for the 15x10 is 7.5"
    IL
    thx for the backspacing....so how tall can i go?
    I ran a 26" tire last season.
    Running a 27" Hoosier this season. And it fills in the wheel well nicely.
    Is your car dropped?? I am not sure I could fit a 28" on my car with the ProKit springs.
    IL
    nope its stock springs. i just have the drag shocks in the back...would the 60 be fine or i have to go lower?
    It would be a tight fit.
    But they can be made to fit.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    i had 325/50-15 nittos on my 15 x 10 7.5" rear backspacing. they would rub in corners, if i went too fast. a 275/60-15 would fit nicely. i currently run a 275/50-15 which is 26" tall. factory height with supplied tires is 25.7".
    major grinding of the calipers is needed to run a 15" wheel in the rear. a 5/16" spacer works for the front to clear the brakes.
    IL
    thx for the info
  1. For Sale: 21" Camaro GM Accessory Rims
    By GmPartsDirect.com in forum Parts For Sale / Trade
    Last Post: 12-21-2012, 08:37 AM
  2. Question: 15" rims on a camaro?
    By Steve's LS1 in forum Camaro / SS
    Last Post: 01-11-2011, 07:09 PM
  3. 2 15"x10 drag rims
    By Hot SS in forum Parts Wanted / Trade
    Last Post: 06-04-2008, 11:36 AM
  4. Does Anyone Know What 15" Rims Fit A 01 Camaro Ss
    By CAJUNCARNUT in forum Wheels and Tires
    Last Post: 01-27-2008, 06:22 AM
  5. drag rims for camaro
    By ls2turbo in forum Wheels and Tires
    Last Post: 04-04-2006, 08:37 PM
