    Member SS-Power's Avatar
    PA
    2000 SS Camaro
    New clutch install?
    Its time for a new clutch and I've decided to go with the ls7 clutch/ ls2 flywheel. Do I have to get the flywheel balanced to the crank? Also I order a new slave cylinder, master cylinder and pilot bearing. Do I use a ls1 pilot bearing or and ls2 pilot bearing? I bought an ls1 bearing, but then I started to second guess myself.
    Alexandria VA
    Should send that back and get the Mcleoud Street Strip and adjustable slave cylinder my.02
    Aug 2000
    Indy
    ^ dork
    Aug 2000
    Indy
    Quote Originally Posted by SS-Power View Post
    nice , how much did it set you back and who did you go through ?
    04 C5 A4 Torch Red - sold
    2009 CTS4 Ice Black - sold
    2013 1500 Silverado Z71 - sold
    02 Z/28 M6 Onyx Black All Options - Sold
    2014 Caddy CTS4 - DD
    2016 Silverado 2500HD
    2020 Caddy XT6
    2020 2SS Vert
    PA
    2000 SS Camaro
    Quote Originally Posted by Danger731 View Post
    a little over $700 and I bought it through work.
    houston
    PEWTER
    2001 Z28
    No, the plate and flywheel do not need to be balanced. You should replace whatever pilot bearing that you currently have. I suspect that would be the needle bearing type, not the sealed bearing type. The LS7 clutch will need to be bled very well, and will still release very near the floor initially. Mine came up to normal after a few hundred miles of use.
    Good luck.
    PA
    2000 SS Camaro
    Quote Originally Posted by todds87ss View Post
    Good luck.
    Ok, good. I hope the install goes smoothly.
    Member TACE02's Avatar
    ASC #753
    2002 Collector's Edition
    what part number is that pilot bearing. if it is: 14061685 then that should be the right one.
  1. clutch install
    By wildbanshee in forum Manual Transmission
    Last Post: 12-20-2010, 08:04 PM
  2. $150 for clutch install.
    By 01ws6er in forum Drivetrain
    Last Post: 03-31-2008, 09:19 PM
  3. help on clutch install
    By blue02Z in forum Manual Transmission
    Last Post: 01-05-2007, 09:05 PM
  4. LS7 clutch install
    By AF1_Z28 in forum Manual Transmission
    Last Post: 02-07-2006, 01:26 PM
  5. Z06 Clutch Install.
    By LiLBear18 in forum Manual Transmission
    Last Post: 09-21-2005, 09:00 AM
