    virgina
    99 trans am
    need some expert help
    Ok iv got a 99 ls1 trans am, bone stock w/ 57,000 miles. the problem is when i first start the car i get a high pitched hum. if i give the motor just a bit of gas it goes away at about 1,500 rpm, or about 60 on the oil pressure gauge.
    but if i do nothing at all and just let it warm up it will hum for 1 to 2 minutes, and just stop instantly. it never comes back untill the next time i start the car. it started only on cold starts but lately it has done it even when the engine is hot. but there has been days when iv gone all day w/ out even a whimper from anything under the hood.
    Please please please any help.
    Feb 2006
    2002 WS6
    Could be your AIR pump, they tend to make noise for various reasons. Usually a high pitched whine.
    drop that access panel below the drivers side headlight and your air pump will be up in there. Start the car and get down there and listen and see if that's what's making the noise. Sounds like it probably is.
    Tulsa,OK
    Quick Silver
    2002 Z06
    +1 for the air pump.. You probably just never used it. Whenver the PCM thinks the cats are cold it will turn the air pump on to push air into the exhaust until they heat up.
    Camaro Owners Click Here
    Firebird Owners Click Here
    www.AutoTrix.net
    Quote Originally Posted by Orcus79 View Post
    another +1 for the air pump... mine sounds like a damn turbo whine untill my car goes in to closed loop...
    virgina
    99 trans am
    how do i fix it. its very annoying, especially when people keep asking me whats wrong with my car.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    to fix it you need to replace it. It sounds like the bearings are going bad in the AIR pump. You could start by unpluging it for a few days to confirm that is the source of the noise, but it may set a SES lite that will have to be cleared out.
    Junior Member 2002blackz28's Avatar
    Jun 2009
    michigan
    2002 camaro z28
    I also just started having a slight whine and think its the air pump going out. Kind of a bumer thinking other people will here it thinking my car is junk. .............Buy once I hit the throttle I don't care. It only does it mabey once or twice a week
  1. Need expert advice.
    By hamptonwsk in forum Computer & Tuning
    Last Post: 06-19-2008, 09:14 PM
  2. Need expert advice!
    By jimmyjones in forum Firebird / WS6
    Last Post: 05-05-2008, 06:28 PM
  3. Expert Exhaust help
    By kool-aide in forum External Engine
    Last Post: 01-14-2008, 02:36 PM
  4. What do you consider yourself an expert at?
    By TWISTEDA4 in forum Almost Anything Goes
    Last Post: 11-26-2007, 10:29 PM
  5. Looking for a 4L65E Expert
    By bismarck in forum GM Trucks
    Last Post: 07-26-2007, 12:22 PM
