Thread: Any LS1Edit tuners still around
04-29-2008, 04:31 PM #1
Ok I have Autotap, LS1Edit, Eflive ver 6. scanner. Car is a 86MonteSS with a 98LS1 A4 out of a 98 Camero SS. I have a decent tune in it, but need help with tweaking more out of it. Took it to track 1st time last Friday nite and ran 12.8/110, 12.8/109 and a 13.1/109. On street tires and stock convertor. So I know it's quick, but logs of runs showed alot tweaking to do. I am just not quite sure how to do some things.(alot lol) I see info on how to do thingd with all the other tuners, but LS1edit is ancient I know but it's what I got. Can't afford big purchase at this time. So anyone still familiar with LS1edit would like to help me out give me a shout.
Thanks Ron
Not sure why Sig is not hereLast edited by 86MonteSS; 04-29-2008 at 04:41 PM.
04-29-2008, 04:44 PM #2
email me a log to [email protected] and I'll look at it. It's been ~3 years since I've messed with edit though.
04-29-2008, 05:10 PM #3
Sent ya an email.
Thks Ron
04-30-2008, 07:27 AM #4Member
- Newport, Mi.
red- 1999 Camaro SS
I have LS1Edit also. The items (or tweaks) that you see posted relative to other tuners, like HPTuners, also apply to LS1Edit. In other words, if someone recommends that you change xxxx to fix yyyy, you should be able to use the same tables in LS1Edit to acheive your goals. The only issue would be if LS1Edit makes that specific table available. BTW: I have successfully tuned my LS2 402 stroker '99 Camaro SS M6 with one of the first versions of LS1Edit and have an acceptable tune, but I am still fine tuning.
'99 Camaro SS; 6-spd, LS2 402 stroker short block, PP stage 3 heads, GMS MAF, 244/248 cam, FLP headers, Borla catback, 4.10 gears, LS6 intake, 39#/hr injectors, Pro 5.0 shifter, subframe connectors, Comp Cams 1.85 rr,
Best ET: 12.23sec (2.000sec 60'), trap spd:117.5mph, with the LS1 engine.
04-30-2008, 08:41 AM #5
04-30-2008, 02:52 PM #6
Track was packed, heard there was over 300. There was alot of cars, I left at 8, was looking at least an hour to make another run so I left.
Had a blast thou, will definately go back this season.
Wanted: lS1edit unlimited ?
By jlast in forum Parts Wanted / TradeReplies: 0Last Post: 09-24-2016, 08:06 AM -
Half Price LS1Edit for 97-03 UNLIMITED VIN# LS1 And LS6 Cars
By fil131 in forum Parts For Sale / TradeReplies: 188Last Post: 07-02-2010, 08:02 PM -
HP Tuners?
By rajiv1998 in forum Computer & TuningReplies: 34Last Post: 04-17-2007, 05:07 AM -
should speed shop do my tune or use ls1edit for all futrue mods??
By greatwhiteZ28 in forum Computer & TuningReplies: 0Last Post: 03-15-2007, 11:44 AM
