Thread: Bad Vibration
    canada
    1997 trans am
    Bad Vibration
    Looking for help/suggestions, 97 trans am AT trans, had a bad vibration around 70-85 mph, then would clear up, felt and sounded like the drive shaft, I removed the drive shaft, had it balanced, and installed new u-joints, now it's worse, the vibration still kicks in around 70 mph but does not go away, it's gets worse as you increase speed. Help ????
    Dcdrummer LS1buckey's Avatar
    Delaware, Ohio
    pewter
    1999 Pontiac Trans Am
    If it got worse after you had the drive shaft balanced I would have to say it was done wrong/badly have it checked again and make sure every thing is installed right and tourqed to spec. Make sure your tires are balanced and in good condition. I dont really see what eles it could be, if it was a tranny mount or engine mount then you would feel it jerk upon acceleration.
    canada
    1997 trans am
    Thanks, I pulled the shaft off last night, i think i have a bearing gone in the rear end somewhere, as i can feel/hear a slight ratcheting noise when i moved the rear yoke by hand back and forth.
    Delaware, Ohio
    pewter
    No prob, Good thing you found that before it was to late and more stuff broke.
    Member transamdude99's Avatar
    East Wenatchee, Washington
    1999 Tran-Am WS7
    hey man, i work for a big tire company up here in washington and we have people coming in all the time wanting their tires balanced because they have a vibration at a certain speed. sometimes its actually just out of balance and other times the tire could be separated. im not saying that this is what it is but check for an outward bulge on the tires. u will need new tires if this is what it is but it's just a thought on something to check if it keeps up.
    canada
    1997 trans am
    Thanks, I just put new tires on, I had them balanced twice, because I thought that might be the problem, but no such luck.
  1. vibration
    By jsmith564` in forum General Help
    Last Post: 02-25-2012, 04:50 PM
  2. vibration
    By ron83 in forum Drivetrain
    Last Post: 03-29-2011, 04:01 AM
  3. Help: Bad Vibration
    By 2001TransAm in forum Drivetrain
    Last Post: 11-24-2009, 06:42 AM
  4. vibration
    By shadowsnkx in forum Drivetrain
    Last Post: 07-31-2008, 06:14 PM
  5. vibration
    By JROBINSON1016 in forum Internal Engine
    Last Post: 03-20-2007, 05:23 PM
