Thread: 3400 stall, any upgrading?
04-26-2008, 04:02 AM #1
just wondering with a 3400 or less stall would a person need to upgrade the rearend? drive shaft? tranny?
04-26-2008, 06:12 AM #2
alot of guys are going with a 3500 stall to start out with then building there motors after, you can run a stall with no other mods and it will not hurt a thing. I have pacesetter long tubes 3" true duals CAI and a few other minor mods, the next thing I want to drop money on is the 3500 stall.
If you are planning on putting in a cam and don't do it all at the same time I would do the stall upgrade first then hcam later.
Hope I helped you and good luck!
04-26-2008, 06:45 AM #3
I put a SuperYank 3500 stall in my A4 and love it. I kinda wish it was a little more aggressive, but it's solid. The only other mod I would consider at the same time is a torque arm, especially since you will be dropping the trans anyway. No need to change rear end unless you want to further help traction (lca, phr).
04-26-2008, 07:53 AM #4
Don't forget to do a tranny cooler. You may also have to get a tune for the stall. When I did mine I had to raise my idle a little bit and move my shift points a little. Some people have to reduce misfire detection which I didn't when I was stall only but had to when I did the cam.
04-26-2008, 08:14 AM #5
thanks for throwing your $.02 in orion, lol i'm just going from what I can remember about what i've been told, I haven't done my stall yet either but it's on the (wish list)
04-27-2008, 05:58 PM #6Junior Member
- Apr 2008
- illinois
red- 2001 Pontiac Trans Am
I ordered my Vig 3600 stall 2 weeks ago and I'm still waiting on it to come in I can't wait to peg the throttle after the break in period!
04-28-2008, 10:20 AM #7
After my Vigilante 3600 stall was in, my car would hit the rev limiter on the 2-3 shift at WOT. Once settings were properly adjusted via HPTuners, all was good.
DEFINITELY invest in a nice, large tranny cooler.
2019 Silverado LT Z71 5.3, 8L90E
2000 Pontiac Trans Am WS6 6.0, 4L80E, 9" rear, TURBO...
9.32@147
04-30-2008, 09:09 AM #8Member
- Jan 2008
- Dighton Massachusetts
Black soon to be red- 2000 Trans am Ws6
rev limiter
Before I even modded my car it would bounce of the rev limiter 1-3? any reason why it`s doing this,is this normal? Also mods now are SLP cold intake,pulley,exhaust.Waiting to be installed are American racing headers w/ catted y pipe,3600 fuddle stall,trans go shift kit,b&m tranny cooler an deep pan,granatelli wires an plugs.
05-03-2008, 07:08 PM #9
An upgrade to a TCI SF-29 flexplate would not hurt either, especially if your vehicle is an 01 or 02, they have pretty crappy stock flexplates.
Sub frame connectors would also help eliminate or damper the wheel hop.
SteveC
~3200-3400 TCI stall
By LeadFarmer in forum Parts For Sale / TradeReplies: 22Last Post: 08-03-2011, 05:22 PM -
3400 stall, works 100%
By cjg454ss in forum Parts For Sale / TradeReplies: 17Last Post: 05-22-2007, 07:15 PM -
3400 stall and shift kit?
By rotwiler in forum Automatic TransmissionReplies: 1Last Post: 05-13-2006, 10:09 PM -
3400 stall with 2.2STR needs to go brand new!
By RS_SS69 in forum Parts For Sale / TradeReplies: 0Last Post: 04-18-2006, 06:41 AM -
Midwest 3400 stall,2.5 (vs ?
By Brianss1 in forum Automatic TransmissionReplies: 2Last Post: 02-23-2006, 01:23 PM
