Thread: Rocker Arms
    Edinburg, Texas
    Rocker Arms
    I have a stock LT-1 with with a few bolt ons. I was wanting to change my rocker arms to either 1.6 or 1.7's if I could. What would I have to do to change to 1.7's? I know how to do 1.6s but can 1.7s be put in with no problems like would I have enough clearance with the valve covers.
    Member cailey37's Avatar
    Mississippi
    1998 Pontiac Trans Am
    Not totally sure but I'm going with the need for either spacers on your valve covers or you'd have to get the tall valve covers....I have 1.6's on my LT1 and they are fine with the stock valve covers.....
    Feb 2008
    San Antonio
    '96 Impala SS & '14 SS
    If you're keeping the stock cam, then the most you MIGHT have to do is trim the baffles on the inside of the valve covers. Spacers are not necessary.
    Oh yeah......change the valve springs while you're at it.
    Finally, you're going to find that your selection of 1.7 rockers is extremely limited.....and those that are out there will likely require 7/16" rocker studs and guideplates.
    KW
    im a chick brynnda's Avatar
    temecula, CA
    white w/NBM stripes
    1997 WS6 LT4 Trans Am
    i run 1.6 an lt4 converted WS6, with no probs
    let the F-Bodies roll jimmybling31's Avatar
    hixson tennessee
    94 camaro z28
    I don't think lt1's can fit 1.7rr's . i know 1.65's but 1.7? I wish I could find some. I would have some fun with that. more lift is always nice.
    Oct 2001
    Colorado
    95 Z28
    I believe it was scorpion that made the 1.7 LT1 rockers. Its been done.
    hixson tennessee
    94 camaro z28
    Quote Originally Posted by 5.0THIS View Post
    shit I'm gonna go find them then. If you see some comp 1.6 roller rockers for sale on here it's because I found some 1.7's that I liked
    Feb 2008
    San Antonio
    The ONLY 1.7 rockers I know of that are NOT shaft-mounted (and were installed on a LT1/4)......were the Scorpions !
    KW
  1. High-Ratio Rocker Arms - Off Your Rocker
    Last Post: 08-19-2011, 02:50 PM
  2. Question: rocker arms
    By william45 in forum General Help
    Last Post: 07-02-2010, 02:13 PM
  3. Help: rocker arms ???
    By ggino85 in forum Internal Engine
    Last Post: 08-24-2008, 08:08 AM
  4. rocker arms
    By 94z28l in forum Internal Engine
    Last Post: 05-30-2007, 11:22 PM
  5. slp 1.85 rocker arms
    By nhraformula in forum Parts Review
    Last Post: 08-13-2005, 01:31 PM
