Results 1 to 15 of 15
    Mount Carmel
    1998 Pontiac Firebird
    Angry Not sure what is wrong!!!
    I have 1998 Firebird with a 3800 II, teh car has run fine since i have owned up until a couple weeks ago... Whenever i drive and it gets up to temp it bucks severely... It doesnt do it when it is cold... It usually only does when i am accelerating but the other say it did when i was cruising... I just replaced the plugs and wires...I heard a couple different things from my local mechanics about it but none were to sure...they said possibly the MAF is bad, the ECM may need to be reflashed, and something about the surge canister solenoid... but i am completely lost...i dont want to spend big money on a new MAF if the isn't the problem... Any help you guys could give me would be grealty appreciated... Thanx
    in my Trans Am
    2000 Trans Am WS6
    well is your check engine light coming on, are throwing any codes???
    Mount Carmel
    The check engine light isn't on but it might be burned out...i put my scanner on it and it keeps telling me the MAF has no activity...but i was told that could be caused by a number of things..
    Cedar Rpaids,IA
    1998 Camaro SS
    If the Maf is dead I would not thing the car would run at all. Other things I can think of that would throw that code would be a bad wire to or from the Maf. The Maf being extremely dirty or having a Maf wire broke. The maf connector could be bad or have some type of corrosion in it. The PCM wire might be broken or the PCM could be having issues. Electronics have been know to temp sensitive. If you know someone with the same type of Maf and does not have any problems. Switch that maf to yours and see if the problem goes away. If it does not then its wiring, connector, or PCM related.
    1998 Camaro SS Hard Coupe Bright Red #1593
    Mods: Lots!!, still my daily driver except for winter
    383rwhp 370rwft/lbs
    1979 Corvette
    Mods Lots!!, weekend cruiser
    325rwhp and 320rwft/lbs
    2007 Dodge Ram 1500 4x4 (Yes its got a HEMI)
    Mods: Catback, BFI CAI, Winter daily driver
    Member red99ws6's Avatar
    tazewell, tennessee
    1999 Trans Am WS-6
    im not sure about these cars but on a ford ranger i had the MAF was bad and it would run but sometimes when i would come to a stop it would die
    I'm gonna move this to the v-6 area so you'll get more specialized answers. The car will run with the MAF unplugged, it goes into speed density. You *may* be getting bad readings from the MAF though causing issues. It does sound like it's MAF related to me.
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    make sure you clean the maf sensor.
    James Bond Spikito's Avatar
    2001 3.8 Black - sold
    2000 SS Black M6
    Holy shit, i keep seeing these same symptoms come up....if you get a P1406 code, or if there is a blinking "E" on the screen, its an EGR error. its a little valvle, front of the motor, drivers side, has 2-13mm bolts and a plug, take it off, hose it our with carb cleaner, if that fixes it, then you need a new EGR. cleaning it fixes it, but only for about 2 weeks. i finally replaced mine last week.
    a new one will run you about $150, and you can install it yourself, you also need a $2 gasket, and they tend to be tricky to find.
    Member jd1666's Avatar
    TX cedar park
    arctic white
    97 firebird
    must be a real POS id just burn it and sell the ashes
    2000 SS Black M6
    Quote Originally Posted by jd1666 View Post
    hey man, lets not be too much of an asshole as when we join the forums
    TX cedar park
    arctic white
    97 firebird
    it was just a suggestion if you dont like it then dont reply
    2000 SS Black M6
    So you're suggesting he toss the car because of one faulty part? jeez if I did that I'd have been through a dozen cars by now.
    This is a camaro forum, people come here to get answers to their problems, if you're not going to contribute constructively, then keep your mouth shut.
    Back to the task at hand....got an update on the car yet?
    Mr. YUK BigBrian442's Avatar
    Pasadena, MAryland
    Purple
    98 Firebird
    Unplug the MAF and see if it stops.
    Shepherd, Michigan
    98' trans am
    Quote Originally Posted by BigBrian442 View Post
    unpluging the maf will switch your car over to a SD tune (speed density) so he is correct..if it stops the error then it is a maf related error
    Shepherd, Michigan
    98' trans am
    welcome to the boards...i am sure you are now familiar with our warning/infraction system...n00b
  1. I think i got the wrong 4.10's
    By karpetcm in forum Drivetrain
    Last Post: 06-29-2012, 04:25 PM
  2. Wrong Place Wrong Time
    By Fearls1 in forum Firebird / WS6
    Last Post: 05-07-2010, 06:26 AM
  3. Something wrong!!
    By dcarver07 in forum General Help
    Last Post: 03-28-2009, 02:28 PM
  4. Help: I think something's still wrong
    By bsteff in forum General Help
    Last Post: 03-17-2009, 06:03 PM
  5. Is it wrong that I
    By FantaZGuy28 in forum Almost Anything Goes
    Last Post: 12-08-2007, 11:15 AM
