Results 1 to 15 of 15
Thread: Gas Cap Issues.............
04-14-2008, 08:09 AM #1
Well has anyone had issues with the wonderful plastic gas cap not latching properly.............?
I'll tell you first hand it throws a code and pops the check engine light on when the system does a self pressure test on the tank. Getting ready to call the stealerships to check pricing and availability.
I might just drill a couple small holes through the top and place a couple short course sheet metal screws through the plastic cover. It seems as if the ratcheting mechanism is just clutching instead of twisting.Don't be afraid of the bottle!!! Be afraid of your tune!!!
04-14-2008, 09:30 AM #2
im pretty sure there was a recall on that........ i havent had a problem so i never brought it in, but i did get something in the mail saying bring it in for free
04-14-2008, 09:39 AM #3
I know there was on the 04's I never got one (letter) about my 05 nor did I have any issues. This is a customers 06 with 23,000 on it. So if they are still junk on 06 why buy another one at the dealer.
I just ended up getting a Stant part #11841. It was $16 @ Checkers.
The dealership was about the same price with my discount $14.37. The GM part # 10372866 .
I figured the Stant would be a better upgrade. I have had their caps on many cars over the years and Never had any issues.
04-14-2008, 10:13 AM #4Grand Imperial Wizard
- Retired Outlaw Sum Bitch
The Pontiac dealer here has replaced all the 04/05/and 06 gas caps at no charge. There is a TSB out on it....
04-14-2008, 01:19 PM #5Junior Member
- Apr 2008
- saudi arabia
red- 2002
thank you
04-14-2008, 05:16 PM #6
04-14-2008, 05:53 PM #7Junior Member
- Apr 2008
- Central Georgia
Yellowjacket- 2004 Pontiac GTO M6
WARNING! What ever you do, don't make the same mistake I did. When mine started giving me problems, I wrapped my fingertips down around the bottom of the cap and tried to muscle it on and sliced the hell out of my fingers... the rounded metal lip is extremely sharp!!!
I got the letter after I had already replaced mine from O'reilys... approx. 7 bux as I recall.
04-15-2008, 02:56 PM #8Junior Member
- Dec 2006
- Connecticut
yellow- 2004 gto
I had the trouble with the gas cap as well, I had it replaced and had the same problem, until I foundout what was wrong. when putting the cap on I was pushing down. DON'T!!! Just place it and turn, it will go on perfectly. Ron
05-09-2008, 02:05 PM #9
07-11-2008, 09:57 AM #10Senior Member
- Mar 2008
- OHIO"S only 9 second GTO
Phantom Black Metalic- 2005 GTO
I replaced one of them GM gave me a new one wanted my old one,then it went bad again so I went to local parts store bought new cap from them drilled hole in it used a screw and wa la no more problems,been on car for 2 years now ,O.. the screw holds factory strap in place in the top like original did.
07-17-2008, 05:37 PM #11Senior Member
- Mar 2008
hope this helps someone.
04-04-2011, 05:42 AM #12Junior Member
- Dec 2010
- Goose Creek, SC
Cosmic Grey- 2005 Pontiac GTO
gas cap
Had the same issue... Bought one from Autozone and it actually took care of the probloem.
04-04-2011, 07:09 AM #13Member
- Jan 2008
- Lowell MI
metallic burgandy- '00Pont Grand PrixGT
I have a 2000 Grand Prix with the 3800 and just replaced the second AZ cap. So counting the factory unit, the car has had 4 caps total now. Last one lasted about 7 months. AutoZone's may be cheap or something, but just doesn't seem right that it is such an issue
04-07-2011, 10:20 AM #14Member
- Jan 2008
- Lowell MI
i almost don't dare to post it...but looks like my latest AZ cap took car of my SES light
AGAIN
01-23-2012, 03:57 PM #15
Bringing this back up... my car threw code P0455, gross leak or something like that. Replaced the gas cap about 20 miles ago, and was wondering about how long should it take for the SES light to turn off? My car needs inspection and this is the only thing stopping me from passing. IIRC the light will go off by itself for certain problems, but other problems can have it needed to be reset by a mechanic.
tv issues
By 2000redcamaro in forum Almost Anything GoesReplies: 15Last Post: 12-24-2009, 09:47 AM -
Q-Jet Issues?
By pajeff02 in forum Classic MuscleReplies: 7Last Post: 09-07-2009, 12:31 PM -
will 20's fit on gto with no issues
By johnjr45 in forum GTOReplies: 4Last Post: 08-11-2007, 04:48 PM -
PM Issues
By schtick in forum Request and FeedbackReplies: 0Last Post: 07-10-2007, 05:54 PM -
Having some serious issues.
By Banshee1967 in forum Suspension and HandlingReplies: 2Last Post: 03-31-2007, 07:45 AM
