Results 1 to 1 of 1
Thread: Car Trailer Basics 101, Part II
04-08-2008, 09:50 PM #1Blown, Stroked, & Sprayed
- Aug 1999
- No Where
We began the subject of car trailers in last month's issue and addressed the basic types of trailers, size, major manufacturers, options, and pricing. In this month's installment, we will address the tow vehicle, hitch setup, towing safety, several driving tips, useful items to have handy, maintenance, insurance, and other options to consider.
The type of tow vehicle that will work best for you depends on the total weight of the car being hauled, the trailer, and any cargo, as well as the type of terrain you will be covering. Typically, manufacturers' tow vehicle ratings specify the trailer tongue weight, as well as the weight of the combined and fully loaded weights at which a tow vehicle can safely tow a trailer. These ratings are usually the maximum allowable weights. Some of the terms you will find are:
- Gross Vehicle Weight Rating (GVWR): Weight for a fully loaded vehicle itself.
- Towing Capacity: Weight a vehicle can tow. This can depend on the vehicle's equipment and type of hitch used.
- Gross Combination Weight Rating (GCWR): Combined weight of the tow vehicle, trailer, passengers, equipment, fuel, and so on that the vehicle can handle.
- Gross Axle Weight Rating (GAWR): Weight a single axle can handle.
- Tongue Weight: The weight of the trailer on the trailer hitch. Not enough tongue weight can cause the trailer to sway, while too much can cause reduced steering response. This is where a weight distributing hitch can help by transferring weight more evenly on both axles of the tow vehicle.
Trailers also have a Gross Vehicle Weight Rating for the weight of the trailer and its contents, and a Gross Axle Weight Rating for the rating of its axles.
We have had several tow vehicles, but found a three-quarter-ton truck to work well. The one we now have is a Silverado 2500HD with the Duramax diesel and Allison transmission. The towing performance, stability, and fuel mileage have been super. Just set the cruise control and let it do the work. Hills are a non-issue with this tow vehicle, which makes driving much more relaxing.
While there are two main types of hitch styles-bumper mount or fifth-wheel-we'll address the bumper style since that is the most common. For the bumper style, the major consideration is the rating of the hitch, use of a weight distribution setup, and the sway control. The hitch should be a Class IV or V with a weight distributing setup. Adjusting the tension on the weight bars is also important, as is setting the height at the hitch ball. The trailer should be very close to level when loaded with the car. Otherwise, you can experience some sway. If you can't get it perfectly level, it's better to have the height at the trailer hitch a tad (1-inch) higher than the top of the tow vehicle ball. You can get ball mounts, which are adjustable to get the ball at the right height. If you do experience sway while driving, any steering corrections you make should be small and slow. Sometimes applying the trailer brakes alone (by using the lever on the brake controller) will help correct the sway.
For the sway control we use a dual-cam-style. Reese and Draw-Tite are two of the better known makes. One model to look for is the Reese PN 26002 and Draw-Tite PN 26000. There is also a single arm friction sway control, such as the Reese PN 26660, but we prefer the dual unit. Another hitch company is Equalizer.
Web sites:
www.draw-tite.com
www.reeseprod.com
www.equalizerhitch.com
You also need a good brake controller. We now use the Tekonsha Prodigy unit, which works well. Some vehicles with the trailer towing option are setup for this controller and allow you to plug right into their pre-installed harness, using the appropriate adaptor harness, which simplifies the setup. The controllers are adjustable for when the trailer brakes come on, as well as the amount of braking. I set the unit to come on just ahead of the truck brakes and with enough pull to feel it working while not locking the brakes. This is especially important in wet or slippery driving conditions. The Tekonsha web site is www.tekonsha.com, and there are many other makes available.
Your tow vehicle will need camper-style mirrors. Many varieties are available from those that clip onto your existing mirrors to those specifically designed for towing. Some trucks are now available with power mirrors, which extend for towing and work great. Even with the widest mirrors, they won't necessarily give you full view along the side of the wide-bodied trailers when backing up, but they are essential for safe driving. We also use small spot mirrors, which help remove the blind spots.
Federal law requires trailers to have taillights, brake lights, side marker lights, turn signals, and side and rear reflectors. Some trailers use a four-way connector hooked into the tow vehicle's electrical system. Many use a seven-way connector that includes an electric brake signal, power supply, and backup lights, in addition to the typical four functions. Your trailer supplier will be able to ensure the tow vehicle and trailer are compatible.
How well you can handle and control your tow vehicle and trailer is heavily influenced by how well the cargo is loaded and distributed. For safe towing, it's best to balance the weight along the length of the trailer, as well as side to side.
Most state or federal laws require safety chains or cables, as well as a break-away switch. The safety chains should be crisscrossed, allow enough length so as not to bind when turning, but not drag on the ground. The break-away switch connects by a small cable to the hitch and, should the trailer become disconnected from the tow vehicle, the cable pulls a plug that applies the electric trailer brakes.
When hooking up or unhooking your trailer, be sure to first chock the tires both front and rear to keep it in place and to keep you safe. In addition to tire chocks, you may also want to consider one of the many tire locks available, which place pressure on both tires. Camping stores have a few different types.
Before you leave for a trip, it's important to check the tire pressures on the trailer, as well as the tow vehicle. On the latter, we increase the tire pressure when towing. Check your owner's manual for their suggestions. Also, check the position of the side mirrors, ensure the safety chains and electrical connections are in place, as well as the operation of all your lights. Double-check the car is tied down securely, that there's no gear to move around inside the trailer, and that the trailer doors are locked.
While towing, consider that you have a large and heavy unit behind you to stop as well as accelerate. Turns need to be taken wider than normal. When making sharp turns, it is advisable to make more of a "square corner" and start your turn a little later than normal to avoid the trailer tires from clipping the curb. You also have to allow more time to get into traffic and need to allow more space for safe stopping. Things will happen more slowly, so plan ahead.
When backing up, it's a good idea to have someone behind you to direct you. Some folks feel that holding the steering wheel by the bottom helps to guide the trailer in the direction you want. By turning the wheel to the left, the trailer will go to the left, turn to the right and it (hopefully) will go to the right. The most important advice is to take your time, know what is behind you, and go slowly.
If your tow vehicle has a transmission "tow mode," that mode can be useful to change the transmission shift points to help handle the additional weight. On the Allison transmission, it also provides for downshifts when slowing down to use the force of the engine instead of placing additional demands on your brakes.
You may also find that buses or tractor/trailer units will cause wind buffeting or a push as they pass. Usually you can feel the push from the wind as they approach alongside, and then as they get just about even with the front of your vehicle, the steering correction you've been making to counter that force will change, and you'll have to readjust your steering. You may find yourself first counter-acting the wind force by steering a little to the left, and, then as they pass, a little correction to the right will be necessary. Larger tow vehicles, more aerodynamic trailers, and the better the sway controls will reduce that effect. Useful ItemsJust to round out the practical things we might need, we also carry a complete tool box, Halon fire extinguisher, hand cleaner, paper towels, 12-volt tire pump, battery jumper, flashlight, and have mounted hooks for clothes. We've also found a winch to be handy, especially when moving a nonrunning car or chassis from place to place. You may not need it often, but, if you do, it's a nice thing to have.
There are other trailer options, such as cabinets, workbenches, closets, finished walls/ceilings, and aluminum wheels, but they are not essential. Something you might not have thought about is to install a camera on the back of the trailer. Our camper had one, and we found it very useful. The one we use on our trailer is available from Camping World, and it includes a 7-inch TV monitor in the truck cab. We mounted the camera on the rear top center of the trailer. It also has a one-way speaker so you can hear the person directing you when backing up. It also has a night-vision feature so you can see well at night. It makes backing up easier, and it's also great to be able to see directly behind the trailer, especially when pulling out to pass or pulling back in. We also mounted a camera under the rear bumper of the truck, which takes care of that blind spot when not towing the trailer. You can install a quick disconnect so you can easily switch between the two cameras.
Now that we have used a camera, we would feel lost without it. Some monitors mount on the mirror or on your visor for easy visibility.
For safety's sake, the most important things to check and maintain are the tires, wheel bearings, and the charge in your winch battery, and hitch setup. Regular greasing of the bearings is a must, as is checking the tire condition, tire pressure, and lug-nut torque. The trailer ball should be lubed with the grease designed for that purpose, and checks should be made of the safety chains, wiring and connections, the weight distribution bars, and sway control. Test your trailer brakes regularly and note how evenly they pull, as well as listen for any unusual sounds.
Beyond that, a good wash and waxing when needed will keep your trailer looking great. That's not a job we look forward to, but we use a Porta-Cable buffer to make that job easier. Your choice of color can also impact how much work you have to do. Usually the lighter colors are easier to maintain.
Most insurance policies will provide the liability coverage for your trailer at no extra cost. However, it will not automatically provide the physical damage coverage. Check with your insurance agent or company to ensure you get the coverage you need and want.
This article started out to cover just the basics, but it just seemed to grow. We hope our suggestions are a help if you are considering buying a car trailer. A trailer is certainly a major investment and not needed or wanted by everyone. But if you like to do your prep work at home or will be traveling long distances, it can come in handy. At the very least, it will give you a nice place to store the lawnmower over the winter.
Here are a few links to sources for rearview monitors. The first one is a wireless setup, which should simplify the installation. Others require running a cable from the camera to the monitor.
- Nevada Products
www.nvproducts.com/rvwireless.htm
- Hitch-Cam
www.hitchcam.com
- Mobile Video Store
www.themobilevideostore.com
- Northside Customs
www.northsideh2.com
- Electronics Pluz
www.electronics-pluz.com/frcorecasy.html
- Visor View
www.visorview.com/trailer_cameras.html
- Camping World
www.campingworld.com
Photo Gallery: Car Trailer Basics 101 - Tow Vehicles And Towing Safety - Corvette Fever Magazine
More...
Trailer Security Guide - Car Trailer Basics 101, P
By Ed Blown Vert in forum CorvetteReplies: 0Last Post: 05-18-2010, 02:50 AM -
By Ed Blown Vert in forum CorvetteReplies: 0Last Post: 05-11-2010, 01:20 PM -
By Ed Blown Vert in forum CorvetteReplies: 0Last Post: 04-08-2008, 09:50 PM
